Get rid of default <p> tags???
Thread begun 10/22/2018 10:48 am by Steve | Last modified 8/04/2020 12:01 pm by Ray Borduin | 3587 views | 7 replies |
Steve
Hello,
How can we get rid of the Paragraph tags being forced in the latest HTML Editor?
https://stackoverflow.com/questions/1977791/turn-off-enclosing-p-tags-in-ckeditor-3-0
config.js has been changed to :
* @license Copyright (c) 2003-2018, CKSource - Frederico Knabben. All rights reserved.
* For licensing, see https://ckeditor.com/legal/ckeditor-oss-license
CKEDITOR.config.autoParagraph = false;
CKEDITOR.editorConfig = function( config ) {
// Define changes to default configuration here. For example:
// config.language = 'fr';
// config.uiColor = '#AADC6E';
// config.enterMode = CKEDITOR.ENTER_P;
config.enterMode = CKEDITOR.ENTER_BR;
config.allowedContent = true;
But still the auto P is forced disregarding this directive:
That should be correct. This file is often cached. Have you tried clearing your cache before testing again? I'll make this change in the extension as well since it seems to be the common preference.
Steve
Yes, the following works:
Thanks. I'll get that updated in the next build.
randyrie405335
<p> tags
I am still getting the <p> tags which adds a double line space. Also, is there a way to get the <li> tags NOT to add a line break. See my attachments. The first attachment is what I'd like the editor's default to be so the bullets line up with the text line. The second attachment is how HTML editor currently codes the <li> tags and and text lines do not display on the same line as the bullets, making the display confusing.
Please let me know how to configure the editor so it will properly display bullets.
Can I get a url to see the issue. Also, can I see a copy of your webassist/ckeditor/config.js file? The best option would be to give me FTP access and a url to the admin and front end so I can see the issue.
randyrie405335
Mal-aligned bullets in HTML Editor
Please see my private message. Let me know if you need anything else. I appreciate your help with this issue.
Add this to your config.js file:
That should fix the p tag issue.
The line break issue is a bit more complicated. Of course you can edit the .css so that the LI element doesn't display those line breaks, which is the default anyway, you must have custom css to make it show.
The other option appears to be to add a plugin to your editor. I found this in a google search on the subject:
https://ckeditor.com/docs/ckeditor4/latest/features/output_format.html
