DataBridge 2: change label structure for the forms
Thread begun 10/19/2018 11:03 pm by Mike | Last modified 10/22/2018 9:36 am by Ray Borduin | 753 views | 1 replies |
Mike
DataBridge create this code for the labels in the forms:
<label class="checklabel" for="name"><input type="checkbox" name="name" id="name" value="1" class="formCheckboxField_Standard" <?php if (!(strcmp((isset($_GET["invalid"])?ValidatedField("insert","name"):""),"1"))) {echo "checked=\"checked\"";} ?> tabindex="3" title="Please enter a value.">&nbsp;Test</label>
The input tag is inside of the label and this behaviour could create conflict in a lot of situation.
For example if I use this css solution for displaying custom bootstrap style checkboxes and radio buttons, I need to move label out otherwise not works:
https://github.com/bantikyan/icheck-bootstrap
So, the correct code should be:
<label class="checklabel" for="name">&nbsp;Test</label>
Thanks for the suggestion. I'll log this as a feature request and could add a configuration option for adding the label before, after, or around the form element.
