JavaScript error in Search Wizard
Thread begun 10/19/2018 1:28 am by María Luisa | Last modified 10/22/2018 9:51 am by Ray Borduin | 4330 views | 9 replies |
María Luisa
I am trying to create a search form using the Search Wizard and when I select the column of my table in the database, I see a JavaScript error that I attached in the screenshot.
I do not know if that is the reason why my search form does not work.
On the other hand, I do not know if this error has to do with another bug that makes the recordset panel of MySQLi Server Behaviors, in which everything is unconfigured when trying to enter a variable. I was informed that extensions only work with Dreamweaver in English. But mine is in Spanish and, when I acquired MySQLi Server Behaviors and Data Bridge nobody informed me that the functioning of my plugins would be defective. I do not think it's a good policy.
I need a solution. Thank you
It appears this was a bug that made it into the release. I've updated the extension, so this problem should be fixed if you re-install Databridge v2.
María Luisa
Hello
Thanks Ray
Then, I download DataBridge again? In his day I made a download of the Beta version that is the one that I have installed in my Dreamweaver CS6. Does this second download override my chances of installing DB on another computer?
regards
Click on "my account" and you will find a link to the latest version of data bridge that you can install. You will be able to install and use the serial number on up to 2 computers and as many dreamweaver versions as you need.
María Luisa
Thanks Ray. I'm going to do it
María Luisa
I deleted my Beta version of DB, downloaded version 2.3.1. and I just installed it.
When I open Create Pages, I get this other error, whose screenshot is attached.
If you click 'ok' from that window is your application preset list blank? Are there any available presets? This might be related to the accented characters in your user folder name?
María Luisa
Well, what happens is that Dreamweaver hangs up.
I do not know if it has to do with the particular characters of Spanish, the truth (I did not see any warnings about this when I acquired MySQLi SB or Data Bridge) but I think that in order to change the language in DWCS6 I need a folder that I do not have en_US ...
I can give you a full refund for your purchases if that is the route you would like to take.
After you click "aceptar" the interface freezes? I don't think it has anything to do with your DW language, but more likely the user name on your computer having accents and it failing to find the correct files or directories.
Accented characters in general end up causing issues, not just the DW language preference. If you post a US phone number or Skype contact information I can do a screen sharing session to try to debug this with you directly.
María Luisa
I have been working with Dreamweaver since 2000 and have always used the application in Spanish. I've never had a problem for that reason taking some simple precautions like using the numbers from 1 to 9 or the letters of the English alphabet to name variables, form fields, or anything else that is going to be part of the code of a page.
I think I'm going to stay with the extensions: there is a project for which I will need them. Maybe I need more help. Thank you
