Adding SecruityAssist Breaks Page
Thread begun 10/12/2018 11:20 am by vernon webb | Last modified 10/15/2018 8:54 am by Ray Borduin | 991 views | 1 replies |
vernon webb
I've used the SecurityAssit Wizard and it's broke the pages of the site. The only way to get the page to display again is by removing the following code:
<?php #require_once( "../webassist/security_assist/helper_php.php" ); ?>
/*if (!WA_Auth_RulePasses("Logged in to users")){
WA_Auth_RestrictAccess("../admin/login.php");
It is probably a missing include file. If you add this to the top:
ini_set("display_errors",1);
Then it should give you more information about why it is failing. My guess is that you don't have all of the necessary files uploaded. Try uploading the entire /webassist/security_assist directory.
