html code shows
Thread began 10/11/2018 7:58 pm by p_vouers282571 | Last modified 10/12/2018 10:44 am by Ray Borduin | 271 views | 1 replies |
p_vouers282571
html code shows
when binding field on page see the right column at https://winterspringstudio.com
I've tried webassist formhtml editor. tinymce and dmxzones html editor 3
I am using cs6, databridge 2 and have removed mysqli SB from my site. I use the mysqli recordset for the page that is part of databridge. I am at a loss!!
if I use mysql record set as vs mysqli then it works like it should!!!
I have totally removed databridge, then did a clean install (btw) databridge 2 and still have same problem. I have numerouse sites made with mysqliSB and they have no problem. Also databridge1 and mysqliSB on working sites with no problem. I'm thinking this is an issue with the new databridge 2. I'm afraid to go back to databridge1 and mysqliSB because even with uninstalling them, the wa extensions seem to leave garbage behind that pops a message up saying certain files aren't found!
Help would be appreciated
UPDATE
If I replace the 2 .php files in the webassist/mysqli folder rsobj.php and the other one with the older versions. Page will display properly. So something in those files are amiss??
The latest version has built in cross site scripting protection. It can be disabled in the ts obj file, for the record set, or in the getColumnVal() call on the page when you want html displayed.
