In the released version - At line 55 of file "(Path)WA_SiteTools_ProgressV2.js" dataType has no properties
Thread begun 10/11/2018 1:04 pm by dhagood355349 | Last modified 10/11/2018 3:15 pm by Ray Borduin | 4126 views | 9 replies |
dhagood355349
While Executing timer in WA_SiteTools_ProgressV2.htm, the following JavaScript error(s)occurred:
Was working fine, then started getting this error.
It implies that it is having trouble connecting to the database to get the data Type. What wizard are your running when you get that error?
I'd make sure you can connect to your database through dreamweaver on the databases panel and try restarting Dreamweaver and running the wizard again. If you still have issues I'll have to set up a screen sharing session in order to look into it with you directly.
dhagood355349
DataAssist Pages.
I've tried all of that, it connects fine to the site. What is messed up is it worked, then stopped working.
Connection file has not changed.
dhagood355349
Is stops (error pops up) during the the Update page creation
Maybe it is an issue with the saved preset you are using and it failed to connect to the database properly when it was created? I'd have to debug this with you in a screen sharing session since I am not experiencing the issue.
dhagood355349
Screen Share
See private
dhagood355349
Screen Share
See private
dhagood355349
What do I need to do here, uninstall everything and start again? I'm stuck..
dhagood355349
While sitting here waiting, I completely removed extension and Dreamweaver, all new files installed.. Same issue.
This sounds like an issue with the preset, table, or database connection. Reinstalling would not make a difference.
Have you confirmed your database connection is working properly? Have you tried using a different preset and a different table?
If you post your phone number I can call and do screen sharing in order to debug the cause and find a solution.
