The code is putting the word 'Array' in my DB rather than placing the info
Thread begun 10/10/2018 3:44 pm by lr_leal239405 | Last modified 10/23/2018 3:33 pm by Ray Borduin | 4827 views | 14 replies |
lr_leal239405
The generated code in this form is putting the word 'Array' in my DB rather than placing the info. You can select one or more than one but either way it puts the word 'Array'. I've attached the doc. It's under 'Services Desired' starting on line 433. Thank you.
You are doing a single insert server behavior with a repeated value. Did you expect this to be inserted comma-separated or multiple rows depending on the Services Desired selections made?
lr_leal239405
I would like it on a single row, comma separated depending on the selections made. Thanks!
In the bindings you will see "Services_Desired[] (csv)" and "Services_Desired[] (array)"
If you choose the (csv) version it will insert the comma separated list.
lr_leal239405
I see the two but how do I select it? Is there supposed to be a checkbox option next to it?
Open up the Insert Record server behavior from the server behaviors panel. Go to the second tab and click the Services_Desired column and then click the lightning bolt to set the value. Then select the (csv) version for insert.
lr_leal239405
unfortunately,to use the 'insert record' server behavior it's asking me to activtate my databridge. So I reset it to 0 so that there are 2 activations remaining. But it still wont' take it. ?
Perhaps you have the DataBridge Beta installed. You would need to purchase DataBridge v2 to activate it now since it has been released.
Try re-installing DataBridge v1 and MySQLi Server Behaviors and that should allow you to activate again.
lr_leal239405
Did the DataBridge recently go up in price? I thought it was a bit less than what I'm seeing today.
Also, I have a download on a website that stops at exactly 1,024mb (or 1Gb). Some of it is using your code, some is custom. But I think Ray, you probably know what is stopping it. I tried manipulating ini file but it still does it. Thank you.
Was the file uploaded and is only 1MB on the server? Download size isn't usually restricted. Upload is. That is why I'm wondering if the actual problem was with the upload and not the download.
The DataBridge price may have increased from the v1 pricing to the v2 pricing.
