Databridge 2: Oct 8, 2018 (Version: 2.3.0) - results pages
Thread begun 10/09/2018 11:12 am by Patrice | Last modified 12/12/2018 12:28 pm by Ray Borduin | 4534 views | 13 replies |
PatriceWebAssist
I ran my first test today of the new DB 2. Nothing crashed when creating the back end admin area. YEAH!! I used the MySQLi set up with no difficulty.
Then I create a page to receive the results of the database. DW wasn't seeng the bindings using the existing Li set up. The only way I could get the results page to deliver results was to set up a second binding with the traditional mysql approach. Revising the admin area, the admin did fill the database and the results did show on the page. But what am I missing if the results page won't recognize the Li version?
<?php require_once('../Connections/biznew2.php'); ?>
<?php require_once('../Connections/biznew.php'); ?>
<?php require_once('../webassist/mysqli/rsobj.php'); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
mysql_select_db($database_biznew2, $biznew2);
$query_Recordset1 = "SELECT * FROM newpc";
$Recordset1 = mysql_query($query_Recordset1, $biznew2) or die(mysql_error());
$row_Recordset1 = mysql_fetch_assoc($Recordset1);
$totalRows_Recordset1 = mysql_num_rows($Recordset1);?>
$RecordsetLi = new WA_MySQLi_RS("RecordsetLi",$biznew,1);
$RecordsetLi->setQuery("SELECT * FROM newpc");
$RecordsetLi->execute();
What am I missing in setting up the results page to receive Li instead of standard?
More detail. I inserted another binding and selected Li in the type. Then the first record showed up. However, in order to apply the "repeat region" the choice was only the non Li version. I couldn't access the second binding that used the Li set up.
PatriceWebAssist
http://biz-websites.com/wabridge2/test.php
testing area
You still have the original recordset as well as the mysqli version and they share the same name.... the page should just be:
$RecordsetLi
Then you can apply the mysqli repeat region on the page and it should all work properly.
PatriceWebAssist
Perhaps I am not understanding how the mysqli repeat region is applied then... I am using the DW Repeat Region function. Is there another option? The DW RR just gives me the "you must create a record set" ....
PatriceWebAssist
Ah... the light is coming on!
http://www.webassist.com/tutorials/Getting-started-with-MySQLi-Server-Behaviors
You will find the MySQLi code is much cleaner, more concise, and easier to read and work with in code view.
Also, if you have an existing page with an existing recordset, just open it from the Server Behaviors panel and switch it to a MySQLi connection and the code on the page will be updated automatically so you don't have to re-apply the recordset to update it.
PatriceWebAssist
Still learning. I used the new set up and in the bindings area I get an error of HTTP Error code 500 Internal Server Error. Where should I look to find what is wrong? Top of page uses this:
<?php require_once('../Connections/postoffice.php'); ?>
$postit = new WA_MySQLi_RS("postit",$postoffice,1);
$postit->setQuery("SELECT * FROM postoffice");
$postit->execute();
Add this to the top of the page... it should then show you the actual error instead of a general 500 error:
<?php ini_set("display_errors",1); ?>
PatriceWebAssist
Thanks... it didn't show any errors.
I started over (again). The binding record set showed up. I don't know what I did wrong though.
Thanks for how to check for errors.
PatriceWebAssist
I'm back in this error again. New project. Steps:
Server Behaviors > WA > MySQLI record set >
But when I see it in Bindings, there is nothing available to me to use. Same error message as above (Internal 500).
I updated to 107. Took out the older bindings on the page in question.
Inserted the display error code.
<?php require_once('Connections/paco_i.php'); ?>
<?php require_once('webassist/mysqli/rsobj.php'); ?>
$news = new WA_MySQLi_RS("news",$paco_i,1);
$news->setQuery("SELECT * FROM news ORDER BY news_date DESC");
$news->execute();?>
$pagecopy = new WA_MySQLi_RS("pagecopy",$paco_i,1);
$pagecopy->setQuery("SELECT * FROM pagecopy WHERE pc_ID = 41");
$pagecopy->execute();
But the page design is totally off in addition to the bindings not working.
I've redone a couple of times, hoping I had just missed a step. Any assistance most appreciated.
