Submit On Load
Thread begun 10/08/2018 12:04 pm by vernon webb | Last modified 10/08/2018 1:17 pm by Ray Borduin | 1947 views | 3 replies |
vernon webb
Submit On Load
I have a page that is currently working when you click the submit button. I want to eliminate that button and have the page submit when the page loads. With the submit button in place it works fine, when I change that to "Before Page Load" it returns a syntax error in SQL.
What are the column bindings set to? Do they rely on a form post variable?
vernon webb
Yes. They say <?php echo ((isset($_POST["uID"]))?$_POST["uID"]:""); ?>
How do I get around that?
You would have to get the value from somewhere else than the post if you want to do the insert without a post. Maybe from the url or the recordset or the session. I can't really say since I don't know the full nature of the page or application you are building. You just can't get values from a form unless a form is submitted.
Probably look at the form elements on the page and see what their value attributes are set to and use that instead.
