DataAssist Multiple Records Update... wizard?
Thread begun 10/04/2018 8:23 am by Mike | Last modified 10/04/2018 5:51 pm by Ray Borduin | 1228 views | 2 replies |
Mike
For "insert, update, results, search, delete" pages is available a wizard (using WebAssist -> Database -> DataAssist Pages) but I'm not found the wizard to create a single page with multiple records to update (using "Multiple Records Update" behaviour).
Is this function available in the new DataBridge or is necessary to create all the contents manually (form, fields, table, etc.)?
Without a wizard, where is possible to have more informations about the correct way to settings everything?
Thanks.
There is no wizard for it. It should just be a matter of showing multiple rows using the repeat selection server behavior and then applying the multiple update server behavior.
This is something that I could help with in a premier support ticket, or if you give it a try I can help you debug the page you are working on and give you tips on how to fix it yourself. (I'd need FTP access and a url to see the page your are working on if you go this route)
Mike
Ok, I've done, no complicated but with a "wizard" it would have been faster (I hope to see a multiple update/delete/insert wizard in the future versions of DataBridge).
Thanks.
