Security Assist
Thread begun 9/23/2018 1:37 pm by dhagood355349 | Last modified 9/24/2018 12:59 pm by Ray Borduin | 3297 views | 6 replies |
dhagood355349
Security Assist
Havent used Security Assist much, and I have a question.
How do you pass off one of the login variables to a query once login is successful.
example, the login page has
$SuccessRedirect = "login.php?loggedIn=1";
How can you turn this to redirect the page with query data. Example: MemberPage.php?Username=Username used in login.
something like this? but don't know where to call it from.
<?php echo($?????->getColumnVal("Log_In_group_Username")); ?
Thanks in advance..
D Hagood
Usually you would just redirect to MemberPage.php and then save the username in the session from the authentication server behavior directly. That way you wouldn't have to pass it in the url where it could be changed but could display or use it anywhere on pages after.
dhagood355349
This post has been deleted.
dhagood355349
Session
See private
The third tab in the authentication server behavior allows you to save as many fields as you want from the authenticated user into the session.
dhagood355349
Session
So I do this on the login page?
Then how do I pass it on to the Memberpage?
some of the tools tell me its old coding... <![CDATA[@@OldIncludeCode@@]]>
Yes, add it on the login page. Saved session variables are automatically available on any pages after they are set. Just make sure the session is started on the page when you want to reference them like:
@session_start();
Please use separate posts for new questions. What causes the old code issue? Where does it appear? Most likely that can just be deleted, but I'd need more information about the context and page content to be sure.
