Dynamic Check Box, update, Your SQL statement failed to execute.
Thread begun 9/21/2018 5:40 am by Mike | Last modified 9/24/2018 9:02 am by Ray Borduin | 1278 views | 2 replies |
Mike
Hello,
I've the page in attachment (see "update.php" in the private message) created with the old version of DataBridge and updated with the new one, that when I click on "update" button, I receive the error "Your SQL statement failed to execute".
The error is only when I update with the checkbox unchecked (when is checked the update process works good).
<input type="checkbox" name="active_imghome" id="active_imghome" value="1" class="formCheckboxField_Standard" <?php if (!(strcmp((isset($_GET["invalid"])?ValidatedField("update","active_imghome"):"".$WADAtbl_imghome->getColumnVal("active_imghome").""),"1"))) {echo "checked=\"checked\"";} ?> tabindex="1">
I've attached also the previous version to compare it (see "update-old-version-databridge.php").
How can I fix it?
Can I get FTP access and a URL to reproduce this issue? I don't see why it wouldn't work, but I'm sure I can figure it out if I can play with the code.
Mike
No problem Ray.
I decided to rebuild from scratch the control panel, too old the web site and I prefer to have a /webassist/ folder "clean".
Thanks.
