Paginator PHP compatible with MySQLi
Thread begun 9/20/2018 3:28 pm by Mike | Last modified 4/10/2020 9:50 am by Ray Borduin | 4923 views | 9 replies |
Mike
I'm searching a "paginator PHP" compatible with MySQLi to use with the new version of DataBridge (to be more specific, in a page with a list of recordset generated with the last release candidate version of DataBridge).
At the moment I'm using this one from DMXzone but is too old and not works:
https://www.dmxzone.com/go/16577/dmxzone-paginator-php
Any suggestions?
Thanks.
I threw together a pagination include that will work with mysqli.
You will need the latest version of the rsobj.php file (version 2.16) in order for this to work.
Just reinstall the databridge beta or mysqli server behaviors to get a rsobj version that will work.
Just add this file to your results page with:
  $rs
= $Recordset1;
  require_once(
"results_nav.php");
And edit the first line to put your recordset name in.
There is CSS in the file that you will probably want to move into your .css file, but it will give you a good start and you should be able to edit it to look like the sample designs you sent pretty easily.
Mike
Great, thanks!
Rokon
  $rs
= $Recordset1;
  require_once(
"results_nav.php");
Dear Ray
Thanks for the nice navigation as I was searching for it too. Meanwhile I am experiencing some problem of showing records. Sometime it shows correctly all the navigation and sometime it does not show the navigation at all.
I saw that when I put in below place 5 then it shows the menu correctly but if I change that to like 10 then the menu does not show up while I have results of 17 and it just show result counter text which shows the total number of results but no navigation shows up.
$SearchPage = new WA_MySQLi_RS("SearchPage",$hadithbd,5);
$SearchPage->setQuery("SELECT * FROM hadith_main_vw");
$SearchPage->execute();
Please send a URL where I can see the problem and FTP access and I'll take a look.
Rokon
Please see the ftp detail in the private message.
Page: search.hadithbd.com/index.php
Search with the word ঘোড়ার লেজ
and select exact match & You will notice the problem
My result shows
Result (s): 1 to 5 of 9 only and no navigation icon for next page.
In the navigation include file, this line:
if ($pages>1) {
should be:
if ($pages>0) {
it uses a zero based index, so when the results show exactly two pages it wasn't displaying when it should.
Rokon
if ($pages>1) {
should be:
if ($pages>0) {
Thanks now it is working!
Rokon
Pagination with custom record selection
Dear Ray
For this pagination is there any way to select custom record number instead of a fix record number always, like from a drop down list if the user select 10 then it should show 10 record and if select 5 then it will show 5 record.
That can be done in your recordset. You have to save a session variable to record the user's choice of how many records and give it a default value of however many records you want displayed at first. Then use that session variable in the recordset code in place of the number of rows to display. It would look something like:
$Recordset1 = new WA_MySQLi_RS("Recordset1",$pubsitepro_site,$_SESSION["RecordsToDisplay"]);
