SITE IMPORT 3.02 doesn't work for me!!
Thread begun 9/10/2009 3:22 am by kakadong | Last modified 9/11/2009 3:46 pm by Dani Chankhour | 3257 views | 3 replies |
kakadong
File menu> Site Import.........
after I installed site import
the file menu doesn't show the site import ....
so i can't use the function .....
I have reinstalled many many times....
it doesn't show Site Import ....
can any one help me ???
OS: XP sp3
DW CS4 (traditional chinese) ....
Jimmy Wu
Do you have any of the other extensions installed? Were there any errors when you installed the product?
I see you have the subscription of super suite. You can try installing Surveyor and seeing if the WebAssist Site Tools show up under the Sites menu. Site Import is run from the Site Tools window, so if you can launch that window, you can access Site Import. If you can launch the Site Tools window, select Site Import from the drop down and hit go.
kakadong
thank you
it works
but i still have a question
when I install many extensions(webassist)
I got a message which means " the newer XXXXX.jpeg is already exist, would you change to this one???? "
not only XXX.jpeg but also XXX.js ,XXX.png , XXX.gif ....
I don't know should I chane it but there are so manymany....
so I click the "YES TO ALL "
then I install all extensions , but some of them become veryvery strange.....
can you tell me what to click ??
"yes to all" ??
"yes" ??
"no" ??
"cancel" ??
Dani Chankhour
You should always Click Yes to All. This should effect how the extension behaves because each extension is stored in its own folder. The extension manager will ask you if you want to replace because the dates on the files have changed.
