105 release errors
Thread begun 9/19/2018 5:23 am by georgina_barrett_187762 | Last modified 9/28/2018 12:31 pm by Ray Borduin | 3415 views | 8 replies |
105 release errors
I have just downloaded the latest version of the MySQLi behaviors. After, when I went to open up any of my files I was getting a red explanation mark on all the SecurityAssist server behaviours, and if I try and open any of my MySQLi recordsets I get a javascript error. I re-installed the previous download I had version 1.04 but I am still have the same errors - I can't do anything at all. I have attached an example of the error I get when trying to open a recordset. I am using Dreamweaver CC version 13
Did you try deleting the winfilecache file in your user configuration folder with Dreamweaver closed? That error is usually resolved by clearing that cache file.
No I tried that. I have uninstalled all my webassist extensions and reinstalled them. When I open a recordset and test it I get the error attached.
This is a different issue. Did the other one get resolved with the cache clear?
This issue appears to be out of date connection files. Try going to Site->Advanced->Remove Connection Scripts
That should force Dreamweaver to put up the correct new versions.
Brilliant thank you - that fixed it.
I don't what fixed the previous issue - I came in to work the next day and didn't get the error.
When I reinstalled the extensions I did install the latest version of the MySQLi server behaviours. It all seems to work.
The only thing I have now (that I didn't have before) is that where I have used SESSION variables from the User Authentication > MySQLi Log In User, to show regions I have red exclamation marks in the Server Behaviors panel. I have attached an example. I have found that if I remove the comment code // Begin Show Region the exclamation mark disappears from the Server Behaviour panel but so does the whole behavior row. It's not a major issue as I can remove that bit of code but I have A LOT of these throughout my sites
Just ignore it for now. Can you send me a page with the issue? I'll take a look and try to get it resolved.
OK thanks, here you go.
It looks like you used the SecurityAssist "Show Region" server behavior. This only works for defined SecurityAssist rules. You must have edited the code in code view after applying to use your own custom comparison. That is why it shows as broken, because it can't be opened and edited by the server behavior after hand coding.
You could use the "WebAssist->Utlilities->Show Region Utility" server behavior for a more general IF statement option, but at this point I'd just ignore the exclamation points.
OK thanks
