eCart Install
Thread begun 9/17/2018 4:43 pm by larry268887 | Last modified 9/18/2018 9:50 am by Ray Borduin | 1742 views | 3 replies |
larry268887
eCart Install
When I installed eCart 6.1.2 and tried to finish installing(part3) it gave me a javascript error. Now I can't uninstall eCart.
How do I uninstall it so I can to try to reinstall it? I'm using DW CC 2018
If you post a US phone number or Skype contact information in the private area of a reply, I'll call you and do screen sharing to help you get this sorted out.
larry268887
phone number
This seems to be an issue with the projectseven extension manager. It may or may not be an issue with our extension, but it appears to work properly if you use the DMXZone extension manager. The extension manager error doesn't give me enough information to debug the problem, so the best solution for now is to use the DMXZone extension manager to install or uninstall the extension if you run into issues.
