Nested repeat region headache...:( Category and Sub-category problems.
Thread begun 9/17/2018 7:46 am by Nathon Jones Web Design | Last modified 9/17/2018 3:10 pm by Ray Borduin | 1008 views | 1 replies |
4 tables...
Documents
Categories
Sub-Categories
CategorySubcategoryDocumentLinkTable
I want to display a list of categories that documents exist in, A-Z, but only if there is a document in any of those categories. Easy enough...
$rsCATS = new WA_MySQLi_RS("rsCATS",$csdbmysqli,0);
$rsCATS->setQuery("SELECT DGPSTdocuments.PSdocumentID, DGPSTdocuments.PSdocumentDELETE, DGPSTcatsublink.categoryID, DGPSTcatgeory.categoryTITLE FROM DGPSTdocuments INNER JOIN DGPSTcatsublink ON DGPSTdocuments.PSdocumentID = DGPSTcatsublink.documentID INNER JOIN DGPSTcatgeory ON DGPSTcatsublink.categoryID = DGPSTcatgeory.categoryID WHERE DGPSTdocuments.PSdocumentDELETE = 2 GROUP BY DGPSTcatgeory.categoryTITLE ASC");
$rsCATS->execute();?>
$wa_startindex = 0;
while(!$rsCATS->atEnd()) {
$wa_startindex = $rsCATS->Index;
<?php echo($rsCATS->getColumnVal("categoryTITLE")); ?>
$rsCATS->moveNext();
$rsCATS->moveFirst(); //return RS to first record
unset($wa_startindex);
unset($wa_repeatcount);
So, as a sub-menu under each category title, I'd like to display a list sub-categories that documents in that category exist in, again A-Z and again only if documents exist in any subcategory.
My understanding is that I must place the sub-category recordset and the sub-category repeat region code within the category repeat region however there are instances where a document won't have a sub-category so I assumed I'd have to use LEFT OUTER JOIN but have hit a brick wall with it.
My last attempt being what I thought was very close to the solution....
$wa_startindex = 0;
<?php echo($rsCATS->getColumnVal("categoryTITLE")); ?><br>
$rsSUBCATS = new WA_MySQLi_RS("rsSUBCATS",$csdbmysqli,0);
$rsSUBCATS->setQuery("SELECT DGPSTdocuments.PSdocumentID, DGPSTdocuments.PSdocumentDELETE, DGPSTcatsublink.categoryID, DGPSTcatsublink.subcategoryID, DGPSTsubcategory.subcategoryTITLE FROM DGPSTdocuments LEFT OUTER JOIN DGPSTcatsublink ON DGPSTdocuments.PSdocumentID = DGPSTcatsublink.documentID INNER JOIN DGPSTsubcategory ON DGPSTcatsublink.subcategoryID = DGPSTsubcategory.subcategoryID WHERE DGPSTcatsublink.categoryID = ? AND DGPSTdocuments.PSdocumentDELETE = 2 GROUP BY DGPSTsubcategory.subcategoryTITLE");
$rsSUBCATS->bindParam("i", "".($rsCATS->getColumnVal["categoryID"])."", "-1"); //WAQB_Param1
$rsSUBCATS->execute();
$wa_startindex = 0;
while(!$rsSUBCATS->atEnd()) {
$wa_startindex = $rsSUBCATS->Index;
<?php echo($rsSUBCATS->getColumnVal("subcategoryTITLE")); ?><br> <?php
$rsSUBCATS->moveNext();
$rsSUBCATS->moveFirst(); //return RS to first record
Am I making this more complicated than it needs to be?
Appreciate any advice offered. Thank you.
NJ
It seems like this code would work. Have you tried writing the SQL statements to the page and checking that they look correct and return results in phpMyAdmin?
