Form Function Setup not working property
Thread begun 9/12/2018 7:17 pm by Kenneth | Last modified 9/13/2018 10:19 am by Ray Borduin | 1141 views | 3 replies |
Kenneth
I am building a standard contact form and put it on a .php web page. when it go to the Form Function tab to setup the email properties I select the Bolt next to the From: the box opens to Select Data Bindings but it won't let me open the Current Working Form to select the Email Field so I can't setup the email properties.
It appears to be working for me in the latest build. Have you tried installing the BETA (link on the top of this web site)?
What version of Dreamweaver are you using?
You could always put in a static email address for now and then open the server behavior on the page after running the wizard to set the dynamic attributes.
Kenneth
I am running Dreamweaver CC 2017, What would the dynamic attribute look like? I may try the new BETA link next.
Once the page is created you can access the email from the server behaviors window and then click on the lightning bolt next to the FROM field. The form on the page should be available at that time with the existing form elements.
