Query with GROUP BY... problem with the new MySQL version 5.7
Thread begun 9/12/2018 12:53 am by Mike | Last modified 9/12/2018 1:29 pm by Ray Borduin | 2487 views | 4 replies |
Mike
Hello,
I'm upgrading an old DataAssist website with the new version (2.2.0 beta) and I've a problem with a query with "GROUP BY" declaration.
This is the error (see screenshot):
1055 - Expression #1 of SELECT list is not in GROUP BY clause and contains nonaggregated column 'website_namedb.tbl_applications.id_applications' which is not functionally dependent on columns in GROUP BY clause; this is incompatible with sql_mode=only_full_group_by
This is the query:
SELECT tbl_products.name_products, tbl_products.applications_products, tbl_products.applications_imagenew_products, tbl_products.url_products, tbl_applications.id_applications, tbl_applications.desc_it_applications, tbl_applications.desc_en_applications, tbl_applications.desc_ru_applications, tbl_applications.desc_es_applications, tbl_applications.desc_fr_applications, tbl_applications.desc_de_applications, tbl_applications.desc_ro_applications, tbl_applications.image_applications, tbl_applications.imagedett_applications, tbl_applications.imageg_applications, tbl_applications.video_applications, tbl_applications.article_applications, tbl_applications.stato_applications, tbl_applications.image_new_applications FROM tbl_products INNER JOIN tbl_applications ON tbl_products.id_products = tbl_applications.article_applications WHERE tbl_applications.stato_applications = 1 AND tbl_products.stato_products = 1 AND tbl_products.applications_products = 1 GROUP BY tbl_products.id_products ORDER BY tbl_products.name_products ASC
How can I fix it?
I'm using the last version of MySQL server (5.7).
Thanks.
The easiest solution is to turn off sql_mode=only_full_group_by. You can ask your hosting provider how to do this, or if you have a dedicated server you can do it yourself through SSH using the command.
Make sure the solution you use works after the restart of the server. This usually means updating the value saved in the MySQL configuration file: /etc/mysql/my.cnf
Mike
Ok, thanks Ray.
A last question, for you it's safe turn off "sql_mode=only_full_group_by" or is better to find a way to recreate the query to maintain the server with the default configurations?
It is safe to turn off that setting.
Mike
Thanks Ray!
