How to check two unique value in the same record of the database?
Thread begun 9/10/2018 8:45 am by tony | Last modified 10/17/2018 8:47 am by Ray Borduin | 3555 views | 11 replies |
tony
Hello all,
I have a form that has two fields that I want to validate. This couple of fields must be unique.
So, how can I validate them?
Have I to set them individually in the WA Server validation SB?
Then I set a conditional region to show only when the two fields do not validate?
I'm trying to do so, but the WA fails even one of the two fields differs.
How can check two fields to be unique during a single insert operation?
The validation should fail only when the two fields appear to be already inserted in the db in another record.
TIA
tony
There is no validation that will work like that out of the box. I think a good solution might be to add a recordset to the page and filter it by the two values and then you can validate that the number of records returned is zero.
tony
Thanks for the reply, Ray,
I created the recordset, (rs_duplicated_fields) so that it will filter the DB table by two fields.
Then I created a WA server validation using the NUMBER rule. I set the validate field with $totalRows_rs_duplicated_fields and set the rule to minimum -1 and maximum to 0.
I moved the validation code under all my recordsets code and it seems to work now.
TIA
tony
tony
Hi Ray,
I created a new website and implemented the same solution, but this time it doesn't work.
I'll try to explain:
now I need to compare at least 3 fields.
So, I created a recordset that should display the records that will have these 3 fields identical.
This is the recordset I use:
SELECT *
FROM registrazioni
WHERE registrazioni.data_scontrino_reg = datascontrino AND registrazioni.ora_scontrino_reg=orascontrino AND registrazioni.minuti_scontrino_reg = minutiscontrino AND registrazioni.numero_scontrino_reg = numeroscontrino
All variables here are compared to the related $_POST variables (as TEXT).
The strange thing is that it works locally (on a qnap webserver that has php 5.5.38), but it doesn't online (PHP 5.6.38).
Online, the validation pass everytime.
Please note that all other fields will validate correctly.
What can I check to make it work?
TIA
tony
The recordset is probably not returning a result. To test that, write the SQL to the page with:
<?php echo($query_rs_doppioni); ?>
Then test that in phpMyAdmin to see what it wrong and how it needs to be adjusted to return the result when you need it to. My guess is that your date field syntax needs to be updated, but I can't tell for sure without looking at the database and query like I'm advising you to.
tony
Hi Ray,
this is something I already tried. I use Navicat for MySQL to run queries directly on the final server.
Here is the query I use to make this test:
SELECT *
FROM registrazioni
WHERE
registrazioni.data_scontrino_reg = '2018-10-03' AND
registrazioni.ora_scontrino_reg = '15' AND
registrazioni.minuti_scontrino_reg = '50' AND
registrazioni.numero_scontrino_reg = '528'
The query results are ok. Some records are displayed. But the validation still (erroneously) pass.
So, the WA validation server behaviour should fail (since $totalRows_rs_doppioni is a number >0).
I attach the WA server validation screenshot related to this check: do you think it is correct?
TIA
tony
tony
Ok I found the culprit (date field: you were right about it, Ray) because I tried to do the same validation excluding the date field from the recordset.
I solved definitely changing the code of the recordset from:
$datascontrino_rs_doppioni = "-1";
if (isset($_POST['data_scontrino_reg'])) {
$datascontrino_rs_doppioni = $_POST['data_scontrino_reg'];
$orascontrino_rs_doppioni = "-1";
if (isset($_POST['ora_scontrino_reg'])) {
$orascontrino_rs_doppioni = $_POST['ora_scontrino_reg'];
$minutiscontrino_rs_doppioni = "-1";
if (isset($_POST['minuti_scontrino_reg'])) {
$minutiscontrino_rs_doppioni = $_POST['minuti_scontrino_reg'];
$numeroscontrino_rs_doppioni = "-1";
if (isset($_POST['numero_scontrino_reg'])) {
$numeroscontrino_rs_doppioni = $_POST['numero_scontrino_reg'];
mysql_select_db($database_conn_registrazione, $conn_registrazione);
$query_rs_doppioni = sprintf("SELECT * FROM registrazioni WHERE registrazioni.data_scontrino_reg = %s AND registrazioni.ora_scontrino_reg = %s AND registrazioni.numero_scontrino_reg = %s AND registrazioni.minuti_scontrino_reg = %s", GetSQLValueString($datascontrino_rs_doppioni, "text"),GetSQLValueString($orascontrino_rs_doppioni, "text"),GetSQLValueString($numeroscontrino_rs_doppioni, "text"),GetSQLValueString($minutiscontrino_rs_doppioni, "text"));
$rs_doppioni = mysql_query($query_rs_doppioni, $conn_registrazione) or die(mysql_error());
$row_rs_doppioni = mysql_fetch_assoc($rs_doppioni);
$totalRows_rs_doppioni = mysql_num_rows($rs_doppioni);
$datascontrino_rs_doppioni = date('Y-m-d',strtotime(str_replace("/","-",$_POST["data_scontrino_reg"])));
Hope this help someone else.
Tony
tony
Hi Ray,
sorry to re-open this thread, but I upgraded the page to DataBridge 2 and I have a little problem:
the problem is still this: trying to block users that enter the same data more than a time ("unique database value" sort of, but checking 4 fields).
So, I entered the WA server validation sb and it has been automatically updated.
See attachment 1.
But validation pass even if I insert the same data.
Here is the recordset I would like to use and check:
$rs_doppioni = new WA_MySQLi_RS("rs_doppioni",$conn_registrazione_i,1);
$rs_doppioni->setQuery("SELECT * FROM registrazioni WHERE registrazioni.ora_scontrino_reg = ? AND registrazioni.data_scontrino_reg = ? AND registrazioni.minuti_scontrino_reg = ? AND registrazioni.numero_scontrino_reg = ?");
$rs_doppioni->bindParam("s", "".((isset($_POST["ora_scontrino_reg"]))?$_POST["ora_scontrino_reg"]:"") ."", "-1"); //orascontrino
$rs_doppioni->bindParam("s", "".((isset($_POST["data_scontrino_reg"]))?$_POST["data_scontrino_reg"]:"") ."", "-1"); //datascontrino
$rs_doppioni->bindParam("s", "".((isset($_POST["minuti_scontrino_reg"]))?$_POST["minuti_scontrino_reg"]:"") ."", "-1"); //minutiscontrino
$rs_doppioni->bindParam("s", "".((isset($_POST["numero_scontrino_reg"]))?$_POST["numero_scontrino_reg"]:"") ."", "-1"); //numeroscontrino
$rs_doppioni->execute();
I tried the code above but it always validate.
So I made the same changes I made in databsridge 1:
$rs_doppioni->bindParam("s", "".((isset(date('Y-m-d',strtotime(str_replace("/","-",$_POST["data_scontrino_reg"])))))?date('Y-m-d',strtotime(str_replace("/","-",$_POST["data_scontrino_reg"]))):"") ."", "-1"); //datascontrino
It still validate even if I insert the same data.
I have already tried to remove the DATE field, but validation pass too...
Is this right or I need to use another method in DB2?
TIA
tony
This is the correct technique, but you shouldn't need to add the reformatting in DataBridge 2. You just change the data type to "t" like:
$rs_doppioni
$rs_doppioni->bindParam("t""".((isset($_POST["ora_scontrino_reg"]))?$_POST["ora_scontrino_reg"]:"")  ."""-1"); //orascontrino
$rs_doppioni->bindParam("t""".((isset($_POST["data_scontrino_reg"]))?$_POST["data_scontrino_reg"]:"")  ."""-1"); //datascontrino
$rs_doppioni->bindParam("t""".((isset($_POST["minuti_scontrino_reg"]))?$_POST["minuti_scontrino_reg"]:"")  ."""-1"); //minutiscontrino
$rs_doppioni->bindParam("t""".((isset($_POST["numero_scontrino_reg"]))?$_POST["numero_scontrino_reg"]:"")  ."""-1"); //numeroscontrino
What does the validation code look like? Maybe that is where the mistake is.
tony
$rs_doppioni
Hi Ray,
please consider the DATE is collected using the datepicker in the dd/mm/yyyy format.
Do DB2 take care of this and convert the date from dd/mm/yyyy to yyyy-mm-dd (database format) on the fly?
Anyway, here is the recordset code and the WA code related to it:
$rs_doppioni
$rs_doppioni->setQuery("SELECT registrazioni.data_scontrino_reg, registrazioni.ora_scontrino_reg, registrazioni.minuti_scontrino_reg, registrazioni.numero_scontrino_reg FROM registrazioni WHERE registrazioni.data_scontrino_reg = ? AND registrazioni.ora_scontrino_reg = ? AND registrazioni.minuti_scontrino_reg = ? AND registrazioni.numero_scontrino_reg = ?");
$rs_doppioni->bindParam("t""".(isset($_POST['data_scontrino_reg'])?$_POST['data_scontrino_reg']:"")  ."""2018-10-16"); //WAQB_Param1
$rs_doppioni->bindParam("s""".(isset($_POST['ora_scontrino_reg'])?$_POST['ora_scontrino_reg']:"")  ."""10"); //WAQB_Param2
$rs_doppioni->bindParam("s""".(isset($_POST['minuti_scontrino_reg'])?$_POST['minuti_scontrino_reg']:"")  ."""15"); //WAQB_Param3
$rs_doppioni->bindParam("s""".(isset($_POST['numero_scontrino_reg'])?$_POST['numero_scontrino_reg']:"")  ."""100"); //WAQB_Param4
Note: the inserted values above ("2018-10-16" and so on) are only temporary; I use them just to be sure the query works. Then, in production, I subtituite them with "-1".
validation:
$WAFV_Errors .= WAValidateNM($rs_doppioni->TotalRows . "",-1,0,""," ,",true,17);
TIA
tony
