select help
Thread begun 9/10/2018 4:34 am by Jamie | Last modified 9/11/2018 9:31 am by Ray Borduin | 3315 views | 7 replies |
Jamie
select help
Hey Ray
Have got a drop down in the back end tht the user can select 'location1', 'location2' or both - these are not dynamic - location1 = 1, location2 = 2 and both = 0
On the front end, have got a dynamic page which am trying to show the relevant content appropriate to that page which am trying to get to show the teammembers based on what they have stored in StaffLocation (either 0, 1 or 2)
If 0, then they need to be shown on both pages, if they are only in 1 or the other location to then show them on that page only.
thanks
What happens when you make the change in the admin? Does it get saved in the database? What column should be filtered on the front end from what table? I'm just a little confused about the details of how it should work and that is preventing me from being able to advise you on how to do it.
Jamie
Yes, it gets stored in the db in the staff table in column StaffLocation (and its saved as either 0,1 or 2)
Then on the front end what table and column are you wanting filtered based on that result. I'm still confused about that part.
Jamie
ok sorry. the page main content is coming from the PageContents rs and the TeamMember rs needs to show the staff based the 2 locations that are in the about navigation drop down: http://clients.motley.site/step/location/salisbury
SELECT * FROM staff WHERE Live = 1 AND (StaffLocation = ? OR StaffLocation=0) ORDER BY StaffOrder ASC
And then use a parameter to set the StaffLocation to 1 or 2 based on which location you are viewing by passing in a url parameter.
Jamie
like this?
$TeamMember = new WA_MySQLi_RS("TeamMember",$DBConnection,0);
$TeamMember->setQuery("SELECT * FROM staff WHERE Live = 1 AND (StaffLocation = ? OR StaffLocation=0) ORDER BY StaffOrder ASC");
$TeamMember->bindParam("i", "".(isset($_GET['loc'])?$_GET['loc']:"") ."", "-1"); //StaffLocation
$TeamMember->execute();
Sure, if you are passing in the StaffLocation value from the url.
