... webassist/mysqli/queryobj.php on line 450
Thread begun 9/07/2018 8:36 am by randyrie405335 | Last modified 9/10/2018 10:51 am by Ray Borduin | 3556 views | 10 replies |
randyrie405335
I've exhausted all attempts to remedy this error:
Fatal error: Uncaught Error: Call to a member function Prepare() on null in /Library/WebServer/Documents/FaithCentre-PG/webassist/mysqli/queryobj.php:450 Stack trace: #0 /Library/WebServer/Documents/faithcentre-pg/donate_money.php(28): WA_MySQLi_Query->execute() #1 {main} thrown in /Library/WebServer/Documents/FaithCentre-PG/webassist/mysqli/queryobj.php on line 450
[which reads ... $query = $this->Connection->Prepare($this->Statement);]
It only happens for just one of my forms on one of my sites. ALL the other forms on the other sites that are similarly configured work fine. I need this to work by Monday so I'm under a tight deadline.
Please send FTP information and a URL for debugging and I can help you debug this issue.
randyrie405335
The FTP credentials are listed in my private message... Let me know if you cannot access
You are trying to insert a value into the column "Cell", but it doesn't exist in your database.
randyrie405335
Yeah... I was working on that when you tested. I've removed the "cell" field from the forms and the database. Please review the "Donate Money" tab and see if you get any errors... the form does not insert nor send its email. The "Donate Time" form sends its email while the very similar "Donate Items" does not. I'm probably too close to this to see what the issues are since I've been pounding on this for three days now.
randyrie405335
I just noticed the only difference between the "Time" and "Items" forms was that the "Items" form included encryption "multipart/form-data" ... when I removed it, the form sent its email. The email extension cannot handle encrypted forms?
Still cannot get the "Donate Money" form to insert its data nor send its email.
Setting the enctype won't have an effect. Something else might have changed.
The Donate money page still isn't working because you are trying to insert into the "Cell" column and that column doesn't exist in the database.
randyrie405335
You must be on the wrong site/page... the current posted Money page does not have a cell field. Are you using faithcentre.info ... /FaithCentre-PG (case sensitive) as the remote directory? I've not removed the old site yet (lower case "pg") until I can get the forms to all work.
Your connection is wrong in the FaithCentre-PG folder. It looks like you have it set to your localhost connection.
randyrie405335
Update
My install of DB v2.2 must have gone corrupt - maybe because I was really pounding out the pages to make my Monday deadline and screwed something up. I removed it from DWCS6 and installed the earlier Beta (which didn't function properly at all), removed the configuration file, re-installed DB v2.2 and rebooted my Mac. After re-configuring DWCS6, I re-ran the Money form and it worked perfectly - no queryobj error.
The form still does not work on my host site and I believe the cause is that the host site is running PHP 5.3. I am moving the FaithCentre site from the host's old server to a newer one running PHP 5.6 and reconfigure the connect script to be the same as my localhost. I'm hoping this will resolve why the Money form will not work on the host even though it does work fine on localhost. I assume the email should work as well since it does for the other two forms.
Thanks for your help with all this, BTW. Your expertise is always greatly appreciated.
And the saga continues...
