Dreamweaver cc 18 problem
Hello, I just installed the dreamweaver cc 2018 and install the MySQLi Server Behaviors plugin through the DMXZone Extension Manager.
I'm finding some problems that I do not know if they have a solution:
-With an option select, the "dynamic" button does not work in the "properties" tab.
-I can not drag a field from the base into the code editor of the dreamweaver. This takes a lot of work, since I usually work all by code.
Can this be solved? which is the most stable version to work with the MySQLi Server Behaviors.
Thank you very much
