Getting a Warning and a Fatal error in PowerGallery
Thread begun 9/05/2018 2:32 pm by rocketboymedia.com | Last modified 9/07/2018 2:20 pm by Ray Borduin | 3876 views | 12 replies |
rocketboymedia.com
Getting a Warning and a Fatal error in PowerGallery2.0.1
Getting a Warning and a Fatal error. What can I do to fix this? Thank you in advance.
Warning: require_once(images/installed.png) [function.require-once]: failed to open stream: No such file or directory in /home/content/14/6266414/html/gallery/admin_gallery/global.php on line 37
Fatal error: require_once() [function.require]: Failed opening required 'images/installed.png' (include_path='.:/usr/local/php5/lib/php') in /home/content/14/6266414/html/gallery/admin_gallery/global.php on line 37
This happens when the server inaccurately identifies our activation code as malicious since it communicates with our server. I'll need FTP access to update the files and fix the problem.
rocketboymedia.com
Thanks How can I PM you
Reply to this message and put the information in the private area and only I will be able to view it.
rocketboymedia.com
OK
I can't seem to connect with that FTP information. Please check it and make sure there are no IP restrictions that might be keeping me out.
rocketboymedia.com
Try this
This should be working now.
rocketboymedia.com
Thank You Ray
Absolutely fantastic, your the best. Thank you so much. :)
rocketboymedia.com
Images not showing up in the gallery
Do you have any idea why the images are not in the galleries?
