YouTube Embed Gets Cleared
Thread begun 9/05/2018 10:03 am by BillHobbs | Last modified 9/05/2018 5:04 pm by Ray Borduin | 1602 views | 3 replies |
BillHobbs
I'm using the HTML editor and noticed that if I embed a YouTube video when I update or open the source window the embed code has disappeared. Is there a setting to prevent this from happening?
Here is an example of the embed code that gets deleted.
<iframe width="560" height="315" src="https://www.youtube.com/embed/4gOx9xD5o1U" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
When I reopen the source code it would have changed to <p>&nbsp</p>
What ckeditor version are you using? You should be able to enable iframes in the ckeditor config file see:
https://stackoverflow.com/questions/16975859/ckeditor-doesn%C2%B4t-read-media-embed-code
BillHobbs
I’m using the version that was with the last Data Bridge.
open the file webassist/ckeditor/config.js
and add the line into the config function area:
config.extraAllowedContent: 'iframe[*]'
