issue with file manager and kcfinder
Thread begun 9/05/2018 8:14 am by Marga-NL | Last modified 9/11/2018 10:15 am by Ray Borduin | 3011 views | 8 replies |
Marga-NL
Hi, I updatend databridge to beta version 2.2.0 because my hostprovider will no longer support php 5.6 from next month. Therefore several customer websites have to be updated. So I am doing a testcase on one of my own websites and switched it to php7.1. On one of the (https) admin pages there is a file manager to upload images. When clicking the folder the new upload window opens (nice layout!). I can upload images. But when I select an image and click the 'done' button, nothing works. I have to close the window. The file field stays empty. What can be the problem?
Is there any way I could get FTP access? I'll have to debug it. It may have something to do with the javascript on the page needing an update.
Marga-NL
Yes, see attachment.
I couldn't get in through FTP, but I think I found the problem.
Please replace this file:
/webassist/kcfinder/filebrowse.js
I've attached a new version that should fix this problem.
Marga-NL
One problem solved, another problem still exists, concerning .htaccess in upload folder and showing the uploaded images on front- and backend.
I'll need FTP access to debug this. At the moment the page seems to be having the first issue where I can't even select an image from the file manager.
Marga-NL
I will send you the details.
The problem was that Kcfinder adds a .htaccess file in your uploads directory. this htaccess file contains a line " Options -ExecCGI " that is not allowed in some hosts and causes an error preventing images from displaying
The solution is to prevent KCfinder from adding this .htacess file. This is easy by goiing to webassist/kcfinder/conf/config.php you will find this line :
'_check4htaccess' => true,
Change it to be false
I've done that for you and the page appears to be working now.
Marga-NL
It works! Thanks Ray!
