Removal of Deprecated_ServerBehaviorsPanel_Support-1.1.0
Thread begun 8/28/2018 10:28 am by larry268887 | Last modified 8/28/2018 3:34 pm by Ray Borduin | 2296 views | 3 replies |
larry268887
I installed the beta data bridge program and still had MySQLi_105 installed. this messed up ecart and data bridge.I have finally removed all webassist extentions but can't remove Deprecated_ServerBehaviorsPanel_Support-1.1.0. Since I can't remove this extension when i install databridge extension the extension doesn't seem to operate properly. When I uninstall dw cc 2015 and then reinstall dw the Deprecated_ServerBehaviorsPanel_Support-1.1.0 is still there along with enable server behaviors 1.0. I can remove enable server behaviors 1,0 with project sevens extension manager but still can't remove Deprecated_ServerBehaviorsPanel_Support-1.1.0.
Do you know how to remove a corrupt Deprecated_ServerBehaviorsPanel_Support-1.1.0 extension?
You can always delete your local Configuration folder, which will effectively uninstall all of your extensions. However installing over the extension with data bridge shouldn't cause issues. If you want to post a US phone number or Skype contact information, then I'll call and help you get everything installed and working properly.
larry268887
Phone Number
larry268887
I have all extensions removed.
