error WA_Email.php on line 6
Thread begun 8/25/2018 8:21 am by Darren | Last modified 9/20/2018 7:35 pm by Ray Borduin | 3970 views | 5 replies |
Darren
testing the email on a contact page and getting the following error
Parse error: syntax error, unexpected T_STRING, expecting T_CONSTANT_ENCAPSED_STRING or '(' in ..\webassist\email\WA_Email.php on line 6
created a blank PHP and getting the same ?
test.php
<?php require_once("../webassist/email/WA_Email.php"); ?>
if (($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST)) { //WA Universal Email
$Email = new WA_Email("test1");
$Email->Redirect = "../index.htm";
$Email->From = "website@mydomain.co.uk";
$Email->addTo("test@mydomain.co.uk");
$Email->BodyFile = "../webassist/email/templates/WebAssist-Block/Block.php";
if (function_exists("rel2abs") && $Email->Redirect) $Email->Redirect = $Email->Redirect?rel2abs($Email->Redirect,dirname(__FILE__)):"";
for ($emailGroup=0; $emailGroup<sizeof($Email->To); $emailGroup++) {
$Email->Subject = "test-email";
$Email->send($emailGroup);
$Email->close();
<!DOCTYPE HTML>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
</head>
<body>
<form action="" method="post" name="test" lang="en">
<input name="testfield" type="text" value="testfield" size="50">
<input name="submit" type="button">
</form>
</body>
</html>
WA-Email.php
ln6 use PHPMailer\PHPMailer\PHPMailer;
ln7 use PHPMailer\PHPMailer\Exception;
directory structure - not sure if the above are directory links or if these are linked to a remote site ?:
webassist\email\phpmailer\src\PHPMailer.php
webassist\email\phpmailer\src\Exception.php
What version of php are you using? I think you may need PHP 5.3 or later to use namespaces, which is what that line does. Can you update to a newer PHP version easily?
Darren
thanks, I am using old version locally but on the hosting service I thought I was using PHP7. checking the settings it was in compatible mode, changed this to PHP7 and now working... very strange as since the hosting service upgrade to PHP7 the website stopped working...
now getting a lot of other errors on other pages but that's for another thread
thank you
Darren
quotes from other threads
Originally Said By: dhagood355349
  What versions of DW will the new DataBridge work with?
  CS6 and Later.
that may explain why the email side is not working, I am running CS5.x and all seems OK, I can setup database connections and the email using databridge(beta) but no emails are being sent either running local PHP7 or on the hosting service. I recreated the page from scratch with no validation and still not working
I am looking out for CS6 suite to buy however do you have a EoL service for CS6. I can not justify the ongoing cost of CC
The email should still work in CS3 and above. Just the advanced querybuilder, and database modeling wouldn't work. The issue with the email isn't related to your Dreamweaver version.
If you post FTP information and a url where I can test I will debug your email page and let you know what the issue is.
Email won't work on your localhost since local servers won't have a functioning SMTP server to send emails. You would have to be using a hosted server for testing email.
Darren
sorry for delay - been waiting for CS6 to arrive as I want to use the other functions...
I found the issue: I changed the following
TO:
if (isset($_POST["subby"]) || isset($_POST["subby_x"])) { //WA Universal Email
and also found I had set the email to use my ISP SMTP gateway, changed this to 'mail' and now all working - thanks again
next step to restore the email page to read from the form as this didn't auto update and recreate the validation
the validation new functions / features for the form looks great :)
