mysqli/authentication.php on line 226
Thread begun 8/24/2018 5:48 pm by randyrie405335 | Last modified 8/24/2018 9:57 pm by Ray Borduin | 569 views | 1 replies |
randyrie405335
re: MySQLi/PHP -- Data Bridge v2.1 -- DWCS6 -- MacBook Pro -- OS X 10.13.6
When I try to logon to a restricted page, I get this error:
Fatal error: Uncaught Error: Call to a member function Prepare() on null in /Library/WebServer/Documents/Leathernecks-PG/webassist/mysqli/authentication.php:226 Stack trace: #0 /Library/WebServer/Documents/Leathernecks-PG/admin_logon.php(18): WA_MySQLi_Auth->execute() #1 {main} thrown in /Library/WebServer/Documents/Leathernecks-PG/webassist/mysqli/authentication.php on line 226
What's causing this and how do I fix it?
That could be an issue with a bad connection or bad column names. I'd have to debug it to be sure. Can you get results from a recordset using the same connection?
