"queryobj php" error
Thread begun 8/17/2018 2:07 pm by randyrie405335 | Last modified 8/17/2018 3:43 pm by Ray Borduin | 804 views | 1 replies |
randyrie405335
I've installed the latest beta version of DataBridge.
When I click on the Update button on my edit page, I now get this error:
Fatal error: Uncaught Error: Call to a member function Prepare() on null in /Library/WebServer/Documents/paSeenix/webassist/mysqli/queryobj.php:480 Stack trace: #0 /Library/WebServer/Documents/paseenix/onlinestore/incl_item_edit.php(29): WA_MySQLi_Query->execute() #1 {main} thrown in /Library/WebServer/Documents/paSeenix/webassist/mysqli/queryobj.php on line 480
I am including the page's code for you to review.
What is causing this and how do I fix it?
This is usually an issue with a bad connection. It looks like your query is based on a connection dBtests, but that connection isn't on the page. It seems like it should be using the paseenix connection like the recordset above it.
When you attach files, please leave them in .php format so I can open them in Dreamweaver.
