MySQLi extension Activation error
Thread begun 8/17/2018 9:37 am by mike404055 | Last modified 8/23/2018 8:46 am by Ray Borduin | 4396 views | 11 replies |
mike404055
I've recently re-installed Dreamweaver CC 2017 and then re-installed the mySQLi extension. After restarting, I try and input the serial numbers but there is a javascript error window behind (see attached). It seems to be looking for a file that doesn't exist. Everything was working fine with CC 2018 until recently when I started getting errors messages from the mySQLi extension (no tables found, wrong type of connection etc.), so I've uninstalled it and installed CC 2017. Now I can't validate it.
I am using 64 bit Windows 10. I've tried uninstalling, reinstalling and get the same every time.
Thanks,
Mike
Please post a US phone number or Skype contact information and I can call you to debug this issue and work out what is causing it.
mike404055
Activation error
Thanks. Skype name in private message.
I was able to reproduce the issue and make a fix. Please reinstall the extension and it should fix this problem.
mike404055
Thanks, but I have a different error message now.
Mike
Sorry about that. I had a typo in one of the files I just updated. I've fixed it. Please reinstall and it should work properly.
mike404055
Validation is working fine now thanks.
1. Can't view Simple view of Recordset. It says the SQL is too complex even when it is the simplest query possible.(see attached).
2. Javascript error in /configuration/ServerBehaviors/PHP_SQL/DynamicSelectList.js - it doesn't actually exist. (see attached).
Plus a few other errors where the recordsets aren't recognised when the page is re-opened.
And errors in the Query Builder - Tables not showing and a javascript error on close (see attached).
This was all working until recently. I really don't know what is going on and I need this to work.
-- Just remove the "LIMIT" statement manually before switching to Simple view.
-- This should have been copied into that folder during installation. Please post a US phone number or Skype contact information and I'll call you to do screen sharing and investigate what might have gone wrong. Possibly a conflict with an older version of the extension installed.
I'll look into your other issues during a screen sharing session as well.
mike404055
Many thanks. Information in private message.
Mike
I can't seem to find that user in my Skype
