HTML Encode issue since using DataBridge Beta
Thread begun 8/14/2018 9:46 am by Nathon Jones Web Design | Last modified 8/14/2018 3:31 pm by Ray Borduin | 1840 views | 3 replies |
When I save text to database from a HTML Editor textarea field, which contains HTML obviously, and then try to display it on a page:
<?php echo($rsTOPICS->getColumnVal("threadTEXT")); ?>
It displays the HTML code and nothing is formatted. This didn't used to happen before I started using DataBridge Beta.
Is there an additional step I should be taking when adding TEXT data to a page via recordset?
Thank you.
NJ
Use:
<?php echo($rsTOPICS->getColumnVal("threadTEXT",false)); ?>
The extension has automatic HTML injection protection and you can disable it by adding the "false" argument at the end.
That hasn't resolved it...
www.nathonjoneswebdesign.co.uk/dgprescribingsupport/forum.php
If you select the View button, it opens a panel with the MySQL TEXT field data which still displays HTML code.
You had a little older version of the rsobj.php file. I updated it and the code works now.
