File extension won't validate on upload.
Thread begun 8/09/2018 10:26 am by BillHobbs | Last modified 8/10/2018 11:50 am by Ray Borduin | 3137 views | 8 replies |
BillHobbs
I've been trying to validate the extension on a file to be uploaded and it doesn't seem to work. I've tried several variations to no avail.
The file will upload if the validation is set to include a blank value.
The upload script:
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "vendorlogos/",
'FileName' => "[FileName]",
'DefaultFileName' => "NoImage.png",
'ResizeType' => "1",
'ResizeWidth' => "350",
'ResizeHeight' => "350",
'ResizeFillColor' => "#FFFFFF" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["SubmitButton"]) || isset($_POST["SubmitButton_x"])){
WA_DFP_UploadFiles("WA_UploadResult1", "vendorLogo", "0", "", "false", $WA_UploadResult1_Params);
The validation script:
if (isset($_POST["SubmitButton"]) || isset($_POST["SubmitButton_x"])) {
$WAFV_Redirect = "error.html";
$_SESSION['WAVT_vendorhome_467_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateFE(($WA_DFP_UploadStatus["WA_UploadResult1"]["fileExtension"]) . "",".gif, .jpg, .jpeg, .png",true,2);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"vendorhome_467");
Is the validation code above the file upload code? UploadResult values can't be validated before the file upload has processed. Try validating with the form element value from the form directly instead of the file extension from the processed upload.
BillHobbs
Thank you for your quick response.
The validation scripts are before the upload scripts. I chose Validation as File Extension. The variable is vendorLogo Extension. When choosing the variable the value is: <?php echo (((isset($_FILES["vendorLogo"]))? preg_replace('/^.*\./', '', $_FILES["vendorLogo"]["name"]) :"")); ?>
It still doesn't work.
I've attached two pics of the screens with the choices I made.
That looks like it would work. Can I get a copy of the page? I'll put it on my localhost and do some testing.
BillHobbs
Here it is. I added a gutted version that had just the upload and validate code.
It is a little confusing, but you need to validate the first value (the full file name) not just the extension... so the code should be:
$WAFV_Errors .= WAValidateFE(((isset($_FILES["vendorLogo"]))?$_FILES["vendorLogo"]["name"]:"") . "",".gif, .jpg, .jpeg, .png",true,2);
When you choose just the extension, then it removes the "." in front, and that won't validate properly. The File Extension validation will automatically strip the file name and validate just the extension part.
BillHobbs
Thank you.
That seemed to work. I do have one other question about security. Can someone upload an executable file like hackme.jpg.php? Is this pretty secure or do I need to add something to increase the security.
Thanks again.
It only would allow .jpg and not .jpg.php files.
BillHobbs
Thanks.
