Error while activating
Thread begun 8/08/2018 3:51 am by Kumel | Last modified 11/21/2018 10:52 pm by Ray Borduin | 5522 views | 23 replies |
Kumel
I already had 2 products from webassist. ie: Data Bridge (Current version: 1.2.4) & eCart(Current version: 6.1.2)
Now i purchased MYSQLI. On Trying to activate the product Its asking for Data Bridge activation code & not mysqli server activation code. I tried entering both serial codes. None worked.
Kumel
I reset activations codes & tried activating data Bridge. Its saying wrong activation code.
Try using the DataBridge BETA serial number.
h3O9J-ZGczX-0yWgD-GHWo3
MySQLi is now included in Data Bridge and it can't tell which version you have installed. I'll look into a better long-term solution, but for now you should be able to use this serial number instead.
Kumel
Im facing issue using "File Upload". Error screenshot attached. & after clicking "ok" loading appears( screenshot attached)
Have you tried clearing your winfilecache.dat file? That error is often caused by an out of date cache. If you continue to have problems, then if you post a US phone number or Skype contact information I can do screen sharing with you and debug the problem with you.
Kumel
This was working all fine. but now I m receiving error again. attached screenshot.
It looks like there is an issue with the activation screen in DataBridge v1 checking for the v2 serial. I'll get that fixed right away and upload a new DataBridge v1 build so you can install it again.
I was unable to find an issue to address in the extension. Please post a US phone number or Skype contact information and I can do screen sharing with you in order to determine the cause and fix for this problem.
Kumel
pvt msg
Please try closing your Dreamweaver and clearing the winfilecache.dat file in your user's configuration folder. This worked for another user experiencing the same issues.
