added MySQLi Insert Record combined with Upload Files and it has crashed a completely seperate page? Eh?
Thread begun 8/07/2018 10:36 am by Nathon Jones Web Design | Last modified 8/14/2018 9:29 am by Ray Borduin | 2314 views | 5 replies |
Created a MySQLi Insert Record form with Image Upload and upon completion it has completely crashed my main admin page which now displays "There is an error in your SQL syntax."
So confused how this is even possible but assume a change has taken place in one of the files in the webassist directory, as a result of adding the form, which is being referenced on the admin page?
Link and user credentials below...
Thank you.
NJ
Details as follows...
I've updated your rsobj.php file to turn on debugging. That will show the error message from the database. It appears the issue is a missing column in your database and isn't related to your other page at all. Take a look.
Thank you Ray. One of the database columns was, indeed, missing.
Upload Files isn't working though? MySQLi Insert Record is inserting the record to database, but the image file name column is blank and the image isn't being uploaded to the directory. A link to the form is detailed below, with credentials above.
Have something changed with the processes in the new DataBridge extension?
Thank you.
NJ
Usually file uploads don't work for one of three reasons:
1) Wrong enctype property for the form tag
2) Bad permissions for the folder specified in the upload server behavior
3) Wrong bindings in the insert
I'm not sure which page is giving you issues exactly, but chances are one of those three things are wrong. File upload has not changed at all in the BETA.
1)
Jeezo….how many times have I missed that?! I honestly think I need to be put down.
Thanks Ray.
NJ
