validation triggering when it shouldnt
Thread begun 8/03/2018 7:19 am by Jamie | Last modified 8/06/2018 10:34 am by Ray Borduin | 1362 views | 2 replies |
Jamie
Hey Ray
On the attached page, whe you go to an entry on that page, if you hit update (not changing anything) the password and confirm validation check fails as 'passwords do not match'. If I then add the password to each input it validates fine.
Not sure why initially they are not the same?
Cheers
Jamie
It is probably your browser filling in the value with a "saved password" from that site. I'm not sure what the best fix for that would be. Potentially renaming the password field so that it wouldn't be recognized.
Jamie
you are correct, it is auto filling. thanks
