Map does not show up
Thread begun 9/09/2009 7:05 pm by justinrovnanik388803 | Last modified 9/11/2009 3:14 pm by Jason Byrnes | 5837 views | 9 replies |
Works fine when testing locally, but fails to display at all when uploaded to my server.
Entire 'google_javascript' folder has been uploaded.
View source shows this:
<html xmlns="http://www.w3.org/1999/xhtml" xmlns:v="urn:schemas-microsoft-com:vml">
<head>
/*wagmp*/
<br />
<b>Parse error</b>: syntax error, unexpected T_STRING, expecting ']' in <b>/home/jrover/public_html/google_javascript/wagmp_map_6.php</b> on line <b>43</b><br />
What am I doing wrong here? I am losing my mind with this...
Can you send a copy of the wagmp_map_6.php file so I can investigate the code at line 43 causing the error. You can compress it into a zip file and attach the zip file to your reply.
I have attached the original file. The problem seems to be with a misplaced quotation mark in ['HotelName"] on line 43:
(eg.)
"<strong>Address:</strong><br />".$row_rsHotels['HotelName”]
When replaced with ['HotelName'] and uploaded to my server, I get the following error in view source:
<b>Warning</b>: mysql_fetch_assoc(): supplied argument is not a valid MySQL result resource in <b>/home/jrover/public_html/google_javascript/wagmp_map_6.php</b> on line <b>74</b><br />
***view source with new 'wagmp_map_6.php' file using dynamic coordinates provided from a recordset called 'rsIndex'***
<head>
<script type="text/javascript" src="http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAtDBpckeaBENJWY5lWVPNyxShyE0kW2mXS8aA0KkFzu6JDlf95RSja3ArBScQpEzGoEgacw4T2uYP4g">/*wagmp*/</script>
/*wagmp*/
function wagmp_map_6() {
if(GBrowserIsCompatible()) {
if(!document.getElementById('wagmp_map_6')) return false;
var map = new GMap2(document.getElementById('wagmp_map_6'));
map.enableContinuousZoom();
map.enableDoubleClickZoom();
map.addControl(new GSmallMapControl());
map.addControl(new GMapTypeControl());
var geocoder = new GClientGeocoder();
var fromAddress = {
enabled: false,
street: '',
city: '',
state: '',
zip: '',
country: '',
full: ''
var icon_0 = new GIcon();
icon_0.image = 'http://google.webassist.com/google/markers/traditionalflat/pacifica.png';
icon_0.shadow = 'http://google.webassist.com/google/markers/traditionalflat/shadow.png';
icon_0.iconSize = new GSize(34,35);
icon_0.shadowSize = new GSize(34,35);
icon_0.iconAnchor = new GPoint(9,23);
icon_0.infoWindowAnchor = new GPoint(19,0);
icon_0.printImage = 'http://google.webassist.com/google/markers/traditionalflat/pacifica.gif';
icon_0.mozPrintImage = 'http://google.webassist.com/google/markers/traditionalflat/pacifica_mozprint.png';
icon_0.printShadow = 'http://google.webassist.com/google/markers/traditionalflat/shadow.gif';
icon_0.transparent = 'http://google.webassist.com/google/markers/traditionalflat/pacifica_transparent.png';
var address_0_0 = {
street: '',
city: '',
state: '',
zip: '',
country: '',
infowindow: 'custom',
infowindowtext: '<span style="font: 12px Verdana, Arial, Helvetica, sans-serif; color: black;"><strong>Address:</strong><br /><br />, </span>',
full: ', , , ',
isdefault: true,
addressType: 'address',
loop: 'rsHotels',
latitude: '',
longitude: '',
markerStyle: 'Google Traditional (flat)',
markerColor: 'Pacifica'
geocoder.getLatLng (
address_0_0.full,
function(point) {
if(point) {
var marker = new GMarker(point, icon_0);
GEvent.addListener(marker, 'click', function() {
marker.openInfoWindowHtml(address_0_0.infowindowtext);
if(!fromAddress.enabled || 'address_0_0' != 'address_0_0') {
map.setCenter(point, 13);
map.addOverlay(marker);
else {
map.setCenter(new GLatLng(37.4419, -122.1419), 13);
<br />
}</script>
</head>
<body>
<div id="wagmp_map_6" style="width: 240px; height: 320px;"></div>
<br />
<div>786</div>
<div>784</div>
<div>783</div>
<div>782</div>
<div>781</div>
<div>780</div>
<div>779</div>
<div>778</div>
<div>777</div>
<div>776</div>
<script type="text/javascript" src="google_javascript/wagmp_maps.js">/*wagmp*/</script></body>
</html>
Thanks!!
The problem is this code:
change line 43:
infowindowtext: '<span style="font: 12px Verdana, Arial, Helvetica, sans-serif; color: black;"><?php echo str_replace("'""\'""<strong>Address:</strong><br />".$row_rsHotels['HotelName”]  ."<br />".$row_rsHotels['HotelCity']  .", ".$row_rsHotels['HotelState']  ." ".$row_rsHotels['HotelZip']  .""); ?></span>',
infowindowtext: '<span style="font: 12px Verdana, Arial, Helvetica, sans-serif; color: black;"><?php echo str_replace("'""\'""<strong>Address:</strong><br />".$row_rsHotels['HotelName']  ."<br />".$row_rsHotels['HotelCity']  .", ".$row_rsHotels['HotelState']  ." ".$row_rsHotels['HotelZip']  .""); ?></span>',
Do I need to change anything called '$rsHotels' on 'wagmp_map_6.php' to the name of the recordset I'm using on my site (which is called rsIndex)?
if rsIndex is the recordset that returns the addresses, then yes, that should be the one used in the wagmp_map_6.php.
Ok so I can now see my map, and it loads the coordinates from my recordset, but I have two problems:
1.) The repeat region (rsIndex) on my page that corresponds to the points on my map has dissapeared, and will re-appear if I delete <?php include("google_javascript/wagmp_map_6.php"); ?>
2.)The map is geocoding the addresses instead of using the coordinates.
Again, if I test locally everything works great, but as soon as I upload them to my server I have problems.
I attached the view source...
1) You are entering addresses, not coordinates so it has to use the geocoder to find the coordinates that correspond to the address you have entered.
You are also using an older version. The newer version of Pro Maps for Google will create an XML File that contains the coordinates for you addresses after the first time you view then map to use the coordinates instead of the geocoder on subsequent visits to the page. If you have Pro Maps V2, You should uninstall your currant version of Pro Maps and install the version available from the download center.
2) Try adding the following code just before the repeat region to reset the recordset back to the first record:
mysql_data_seek
($rsIndex0);
$row_rsIndex mysql_fetch_assoc($rsIndex);
All problems solved
Thank you so much, Jason!! You are a master!
You're welcome.
