pass insert page radio button value to update page
Thread begun 8/02/2018 11:57 am by tmcbinc99963 | Last modified 8/02/2018 3:23 pm by Ray Borduin | 1032 views | 3 replies |
tmcbinc99963
This post has been deleted.
I had to add code to mark the previous value as checked like:
<?php echo($row_TestimCo["LubeFK_ID"] == $row_TestimLube['LubeTypeID']?"checked":""); ?>
tmcbinc99963
While you were replying, I adjusted the recordset to include a GET[ID]. This allowed the radio button to return the correct value, so I deleted the original post, thinking I had found a solution.
However, I now only get the one unchecked value.
Added a new Repeat Selection and included your 'checked' code, but nothing changed.
Also added a new Multiple Update server behavior, similar to the checkboxes; same result.
Checked the wizard and found had I selected the wrong repeat field. When I change the repeat field, the wizard won't accept it (the top entry from the list always reappears). Tried multiple times; restarted DW; still same result.
We should do a premier support ticket to work on this page. There is too much going on for me to debug here. Selecting the radio button I have fixed on the live page, but the update doesn't work for other reasons.
