Data Bridge Beta V2
Thread begun 8/01/2018 2:18 pm by JBWebWorks | Last modified 8/03/2018 4:17 pm by Ray Borduin | 5059 views | 18 replies |
JBWebWorks
Data Bridge Beta V2
Just downloaded the Data Bridge Beta V2 and the data assist pages work fine. Recordset and connection works fine.
I am having a problem with Send Email (used to be Create an email) In the other version, when it gets to mail body, you could not use a file and edit directly in DW. In the new version, you must use a file template and that doesn't work for me. Not sure what I am doing wrong. It gets to the success redirect but no email is delivered.
On firefox I get this error message:
Warning: require(webassist/email/templates/basic-simple/Basic_2.php) [function.require]: failed to open stream: No such file or directory in /home/bigchick/public_html/webassist/email/WA_Email.php on line 263
Fatal error: require() [function.require]: Failed opening required 'webassist/email/templates/basic-simple/Basic_2.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/bigchick/public_html/webassist/email/WA_Email.php on line 263
Here is my code on the Send Email page
error_reporting(E_ALL);
ini_set('display_errors',on);
<?php require_once('webassist/mysqli/authentication.php'); ?>
<?php require_once('webassist/mysqli/rsobj.php'); ?>
if ("" == "") {
$RestrictAccess = new WA_MySQLi_Auth();
$RestrictAccess->Action = "restrict";
$RestrictAccess->Name = "authenticate";
$RestricAccessRedirect = "admin_login.php";
if (function_exists("rel2abs")) $RestricAccessRedirect = $RestricAccessRedirect?rel2abs($RestricAccessRedirect,dirname(__FILE__)):"";
$RestrictAccess->FailRedirect = $RestricAccessRedirect;
$RestrictAccess->execute();
<?php require_once('Connections/connmysqli.php'); ?>
$rs_kshoc = new WA_MySQLi_RS("rs_kshoc",$connmysqli,1);
$rs_kshoc->setQuery("SELECT * FROM ksforum_users");
$rs_kshoc->execute();
<?php require_once("webassist/email/WA_Email.php"); ?>
if (($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST)) { //WA Universal Email
$Email = new WA_Email("emailgroup_2");
$Email->Redirect = "?success=true";
$Email->From = "KSHOC <kshoc@jbwebworks.com>";
$Email->ReplyTo = "".((isset($_POST["from1"]))?$_POST["from1"]:"") ."";
$Email->ReturnPath = "jb@jbwebworks.com";
$Email->BurstSize = "200";
$Email->BurstTime = "1";
$Email->WaitTime = "1";
$Email->addToFromRS("rs_kshoc","user_email");
$Email->addAttachment("".((isset($_FILES["attach"]))?$_FILES["attach"]["name"]:"") ."");
$Email->BodyFile = "webassist/email/templates/basic-simple/Basic_2.php";
if (function_exists("rel2abs") && $Email->Redirect) $Email->Redirect = $Email->Redirect?rel2abs($Email->Redirect,dirname(__FILE__)):"";
for ($emailGroup=0; $emailGroup<sizeof($Email->To); $emailGroup++) {
$Email->Subject = "".((isset($_POST["subject1"]))?$_POST["subject1"]:"") ."";
$Email->send($emailGroup);
$Email->close();
The code looks ok. Try changing the trigger for the email to use the button press instead of current form submit trigger.
The attachment code looks wrong. It is just referencing the name of the attachment and not the location where it is saved. That could be an issue as well.
JBWebWorks
Ray,
I changed the trigger with no results. It goes to the success page but no emails are being sent. This is a form sending to a Fraternity group and there are 179 email addresses. It goes to the success page in seconds instead of 179 seconds. I have used this with an older version of UE and it works there. Not sure how to use the email template to get the subject and message from the form to send as the email body. When I downloaded Databridge Beta V2, I guess I received the newer version of UE. I must be doing something wrong setting up the Send Email.
JBWebWorks
I received this error which may be the problem.
Fatal error: require() [function.require]: Failed opening required '/webassist/email/templates/WebAssist-Block/Block.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/bigchick/public_html/webassist/email/WA_Email.php on line 263
Yes, you will need to upload that file.
JBWebWorks
Upload to the server? Yes, I had manually done that.
http://www.jbwebworks.com/webassist/email/templates/WebAssist-Block/Block.php
JBWebWorks
This post has been deleted.
It shouldn't give that error if the file was uploaded. Are you still getting the same error. If you give me FTP access and steps to reproduce I can debug it for you and let you know what is wrong.
JBWebWorks
FTP info in PM
I am not getting the error but the template page was always uploaded.
It is not sending emails but it is going to the successful redirect? There are 154 emails in the recordset that should be sending.
I remember in the older versions of UE, you had to put in your mail server and port. I didn't see anywhere to do that on this version?
I think the only issue is that the recordset was only returning one result. I updated line 7 from:
$kshoc = new WA_MySQLi_RS("kshoc",$connmysqli,1);
$kshoc = new WA_MySQLi_RS("kshoc",$connmysqli,0);
That should make it return all results instead of just the first row.
