Detail Page Drop Down
Thread begun 9/09/2009 6:52 pm by mike292921 | Last modified 11/19/2010 9:57 am by Jason Byrnes | 10693 views | 15 replies |
mike292921
I created a detail page and wanted to know what the easiest way to do a drop down menu if for an item that needs a size selected and then for an item that doesn't doesn't have a drop down.
Ya, I do need to learn more php if statements, etc. Is there a tool that can make this easier with webassist.
What needs to be done.
I hope that made sense.
How are determining whether the item needs a size drop down or not? Figuring this out is the first step to creating the if statement.
For an example, I will assume you have a category column in your recordset that is being used, and if the category equalls "shirts" or "pants" you want to show a select list of sizes, all others, use a hidden form element set to "n/a"
<?php if($row_RecordsetName['ColumnName'] == "shirts" || $row_RecordsetName['ColumnName'] == "pants") { ?>
<select name="size" id="size">
    <option value="s">Small</option>
    <option value="m">Medium</option>
    <option value="l">large</option>
    <option value="xl">X large</option>
    <option value="xxl">XX Large</option>
</select>
<?php } else { ?>
<input name="size" type="hidden" id="size" value="n/a" />
<?php } ?>
mike292921
Thank You Jason
I am going to try this, thank you so much for your help.
One more thing how can I push the size into the description part of Ecart
To get the size into eCart, you will need to create a new column in the eCart object name d "Size" make sure to check the Unique attribute when creating the column.
In the add to cart button, select the Size column and set it to be updatable from a select list. eCart will then add the select list to your page for you.
use that select list in the if statement example from above, and create a hidden form element with the same name for the else statement.
on the bindings panel, expand the eCart section and select the Size column, In the description column of the cart display, place your cursor where you would like the sizer to display, then click the insert button near the bottom right of the display tab.
mike292921
What if I am using Paypal Standard
kinda confused so when I create the add cart button I did that step, it creates an echo now how do I insert the If statement
With PayPal Standard, on the confirm page, there a re a number of hidden form elements used to pass item information. A description is not passed, but the name is, you coul concatinate the size onto the name.
Change the name hidden form elemertn which will look like:
<input type="hidden" name="item_name_<?php echo $eCart1_Index+1; ?>" id="item_name_<?php echo $eCart1_Index+1; ?>" value="<?php echo $eCart1->DisplayInfo("Name"); ?>" />
<input type="hidden" name="item_name_<?php echo $eCart1_Index+1; ?>" id="item_name_<?php echo $eCart1_Index+1; ?>" value="<?php echo $eCart1->DisplayInfo("Name"); ?>| Size: <?php echo $eCart1->DisplayInfo("Size"); ?>" />
mike292921
Thanks again Jason
Thank you for your time.
This is too advanced for me. Will take me a while to learn.
But I appreciate everything.
mike292921
Just one more question
Is there any way I can just add a post action to the description to add the size to keep simple. So it can have both the database value and a post value?
That is actually going to be more difficult to code than what I suggested earlier.
mike292921
Got to laugh
It was worth asking. I really have to start studying more. I am happy I made it this far.
