jquery validation message won't dissappear
Thread begun 7/29/2018 4:38 pm by danielsebas | Last modified 8/20/2018 5:01 pm by Ray Borduin | 3228 views | 8 replies |
danielsebas
Hi Ray, I am using a form in a bootstrap modal and using the following code to make the jquery validation messages disappear if I close the modal:
<script>
$("#myModal").on("hidden.bs.modal", function () {
// put your default event here
document.getElementById("nombres_waerror_errorMsg_wrapper").style.display = 'none',
document.getElementById("celular_waerror_errorMsg_wrapper").style.display = 'none',
document.getElementById("email_waerror_errorMsg_wrapper").style.display = 'none',
document.getElementById("Security_Code_1_waerror_errorMsg_wrapper").style.display = 'none';
</script>
The code works well, but when the form is sent and the server validation fails the code won't work in all the fields and when I close the modal the captcha image validation message won't disappear.
In your server validation use spans like this:
<span id="mensaje_ServerError">el código de la imagen es incorrecto</span>
Give it an id that is = "FieldName_ServerError"
Then it will convert the server error to a jquery html5 validation error when the page loads and it will work with your existing code.
danielsebas
Thank you Ray, I put the span tags, but still after server validation If I try jQuery validation the messages still won't disappear when I close the modal.
Can I get a URL to see the issue live? I'll take a look and see if I can spot the problem.
danielsebas
Hi Ray, you can find the issue in this page by clicking at the bottom right of the image where it say: SOLICITAR COTIZACION
http://www.dewaltcenter.com.ec/detalles.php?producto=120
Thank you
It appears the issue is that it won't show the error when the modal isn't open.
On your page you have:
<script>
var cotizacion_Opts = {
focusout: true,
focusin: false,
change: false,
keyup: false,
popupClass: "DeWalt",
pointedAt: "left",
fieldOffset: 60,
fieldMargin: 2,
position: "left",
direction: "right",
border: 1,
offset: 25,
closeText: "✖",
percentWidth: 100,
orientation: "top"
function cotizacion_Validate() {
$("#cotizacion").h5Validate(cotizacion_Opts);
$(document).ready(function () {
ConvertServerErrors(cotizacion_Opts);
</script>
<script>
$(document).ready(function(){
// Show the Modal on load
$("#myModal").modal("show");
</script>
Try changing the order so that the modal is open before the validation initiates like:
<script>
</script>
<script>
focusout: true,
focusin: false,
change: false,
keyup: false,
pointedAt: "left",
fieldOffset: 60,
fieldMargin: 2,
position: "left",
direction: "right",
border: 1,
offset: 25,
closeText: "✖",
percentWidth: 100,
orientation: "top"
</script>
danielsebas
Hi Ray, I change the order of the validation scripts, but still doesn't work. I also noticed that the query validation not always appear in place and sometimes they appear cutoff.
Thank you.
Regards,
Daniel
I played around with it and I had to add a timeout to wait for the window to slide into view before displaying the error messages. It should be working properly now.
danielsebas
Thank you Ray
