Text field blank in Update admin page
Thread begun 7/26/2018 1:52 pm by tmcbinc99963 | Last modified 8/02/2018 1:04 pm by Ray Borduin | 1975 views | 4 replies |
tmcbinc99963
I've inserted records into a database using an admin insert page. The records insert fine. When I go to the Update admin page, the Testimonial Company field is blank.
Insert Single Record server behavior setup:
General tab, a 'WA_TestimCompany' session variable was created.
Binding tab, I used the Insert_Sharp_Default > TestimCo (text field name).
Update Single Record server behavior setup:
General Tab value is set to the 'WA_TestimCompany' session variable.
This is the same way the other working text fields are set up. What am I missing?
Files attached.
It looks like you aren't filtering your TestimCo table with the $_GET["ID"] value... you just have:
"SELECT * FROM Testim_company"
You are going to have to filter that recordset if you want to return the row associated with the record being viewed.
tmcbinc99963
Tried filtering using the following options:
• TestCo_ID = session variable > WA_TestimCompany
• TestCo_ID = URL Parameter > TestCo_ID
• TestCo_ID = form variable > WA_TestimCompany
• TestCo_ID = session variable > TestCo_ID
I expected the first session variable option to work, but not the others.
As a last resort, tried switching the recordset to the 'prod' table and INNER JOIN the Testim_company table in order to use the $_GET["ID"] runtime value.
All options returned a blank field as before, even after clearing history, emptying cache and restarting browser.
I would think you could filter it by the same $_GET["ID"] variable. I would also think that an INNER JOIN would work if you used the correct column names and then updated the recordset name when referencing the values.
tmcbinc99963
This post has been deleted.
