Support for PHP 7.2+
Thread begun 7/24/2018 9:21 am by snakeeyes1314512 | Last modified 7/24/2018 11:14 am by Ray Borduin | 3256 views | 6 replies |
snakeeyes1314512
What is the highest level of support that you are offering for php?
It depends on the product. MySQLi Server Behaviors, ECart, and the Data Bridge BETA all work on the latest version of php 7.
snakeeyes1314512
When testing with php 7.2.4 I get these errors when not logged in. When logged in the error goes away. It works in 7.1.16 with no issues.
Warning: sizeof(): Parameter must be an array or an object that implements Countable in webassist\mysqli\authentication.php on line 327
Warning: Cannot modify header information - headers already sent by (output started at \webassist\mysqli\authentication.php:327) in \webassist\mysqli\authentication.php on line 450
Can I see a copy of your authentication.php file?
snakeeyes1314512
See attached
I've updated the installer and this file to correct the issue. I've attached a copy here as well.
snakeeyes1314512
