Left Menu Layout Problem in IE7
Thread begun 9/09/2009 4:47 pm by anitah355532 | Last modified 9/15/2009 9:52 am by Jimmy Wu | 3495 views | 5 replies |
anitah355532
I have a problem with the left menu, where it is being cut off in older versions of Internet Explorer. I havn't changed your Powerstore files much, and I don't think I've done anything that would have changed the layout of the left menu.
The menu looks fine in IE8, Firefox, Opera, etc - but cuts off in IE7 (and probably earlier versions).
I've attached a screen print so you can see what I'm talking about.
I've tried everything I can think of to resolve this. Do you have any suggestions?
Jimmy Wu
Do you have a url where I can see this issue? I have not seen this happen on any of our test sites.
anitah355532
www.voyagermoon.com
Jimmy Wu
This may be caused by the -17px margin applied to the ul of the left column box. Try changing those margins to 0.
anitah355532
Thanks Jimmy - all sorted now.
I needed to move the left menu over to fit more text on the line. To do this I changed the margin value (in content.css) and this caused a problem in IE7.
The solution was to use 'padding' instead of 'margin-left':
#sideMenu ul {
margin-top: 17px;
margin-bottom: 10px;
margin-left: 0px;
padding: 0px 0px 0px 24px;
Jimmy Wu
Glad you got this all sorted out.
