Just switched hosting and getting this error on my contact page
Thread begun 7/20/2018 2:24 pm by JBWebWorks | Last modified 7/23/2018 10:04 am by Ray Borduin | 2401 views | 4 replies |
JBWebWorks
Notice: Undefined index: captcha_Security_Code_1 in /hermes/bosnaweb20a/b2150/ipw.pinnaclemgtnet/public_html/contact-us.php on line 21 Warning: Cannot modify header information - headers already sent by (output started at /hermes/bosnaweb20a/b2150/ipw.pinnaclemgtnet/public_html/contact-us.php:21) in /hermes/bosnaweb20a/b2150/ipw.pinnaclemgtnet/public_html/webassist/form_validations/wavt_scripts_php.php on line 85 Warning: Unknown: open(/var/php_sessions/sess_365c3593053c997b84a610aa9a273eec, O_RDWR) failed: No such file or directory (2) in Unknown on line 0 Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/php_sessions) in Unknown on line 0
Maybe sessions aren't working properly on the site.... possibly a bad session_save_path in the php.ini file.
Try saving a session variable on one page:
session_start();
$_SESSION['test']= "works";
and then print its value on the next page like:
session_start();
var_dump($_SESSION['test']);
If session variables aren't working that would explain the error.
JBWebWorks
Ray,
I did that and the print value of the SESSION was NULL
Not sure what that means?
It means that sessions aren't configured correctly on your server. Most likely a bad setting for session_save_path in your php.ini file.
Show the two pages to your hosting provider and they should be able to fix it for you.
JBWebWorks
Thanks Ray.
Yes they changed the session.save_path to 4;/hermes/phpsessions
and that fixed the problems.
