security assist authenticate user to mysqli
Thread begun 7/20/2018 10:11 am by Jamie | Last modified 7/20/2018 11:54 am by Ray Borduin | 1833 views | 2 replies |
Jamie
Hey Ray
From the session the other evening am trying to update the login (attached login.php) page to mysqli and have opened the server behaviour and then update the database to the connection 'DBConnection' (resulting file attached login_mysqli.php) and then I only get this error
Warning: require_once(webassist/mysqli/authentication.php): failed to open stream: No such file or directory in /home/motle7bk/public_html/clients/xyntra/login.php on line 35
Fatal error: require_once(): Failed opening required 'webassist/mysqli/authentication.php' (include_path='.:/opt/alt/php54/usr/share/pear:/opt/alt/php54/usr/share/php') in /home/motle7bk/public_html/clients/xyntra/login.php on line 35
not sure what files are missing or need to be updated?
Cheers
It looks like you may have just not uploaded the file: webassist/mysqli/authentication.php
Perhaps it wasn't created properly? It would probably be created if you opened up and re-applied the server behavior.
Jamie
yup, had to reapply...now it loads fine
cheers
