Multiple Google Pro Maps with Directions on the same page
Thread begun 9/09/2009 4:26 pm by purchases213031 | Last modified 9/10/2009 9:09 am by Jason Byrnes | 3603 views | 3 replies |
purchases213031
I have a page that I have added two maps each with their own directions form. I have been able to get the first map to work and list directions, but the second one does not display directions.
I believe it probably has something to do with the names of the objects, but I just can't seem to be able to make it work.
Both maps where created with the Google Maps Wizard.
Here is the page I have, contact-us.php.
I think you need to be a little more specific on the destination address, try using:
804 W Texas St, Fairfield, CA 94533
instead of:
804 Texas St, Fairfield, CA 94533
purchases213031
Issue Resolved
Thank you! Thank you!
I have been wrestling with this for a whole day.
That was the solution. I will keep that in mind in the future.
Is there any way to troubleshoot these kind of problems? I never saw any errors or was able to see any messages.
Google wont throw an error on this sort of problem.
The method I used was to go to maps.google.gom and past your address in to the search field:
Google displayed the map, but asked me if I meant to use:
804 N Texas St, Fairfield, CA 94533
or:
When calculating the directions, if the same address exists in two location like N Texas St, or W Texas St, google will get confused if you dont tell it which one to use.
