Is there a completed version of Data Bridge that actually works? Every page I generate with DataAssist is generating a "currently unable to handle this request. HTTP ERROR 500" I'm using CS5 and php version 7.0.30 mysql version 5.6.39
Thread begun 7/18/2018 8:45 am by Lola | Last modified 7/18/2018 11:01 am by Ray Borduin | 4728 views | 10 replies |
Lola
http://ourfurkid.com/QRCode/ofkprofiles_results.php
http://ourfurkid.com/QRCode/QRCode/insertfurkid.php - It also created this page when I had already created http://ourfurkid.com/QRCode/insertfurkid.php as the page and location I wanted it on. No idea why this happened.
Image 1.png Shows a page I just created in DW with databridge dataassist. Please notice the Databases panel showing my database connection.
Image 2.png shows the No Database Found Error when opening dataassist again to create another page.
Image 3.png shows the database connection available after I acknowledge the previous error message.
Image 4.png shows that I am in the creation page of the plugin, but also shows my file manager which shows an updated time for the creation of _mmServerScripts because everytime I get that Database error in image 2.png acknowledge the error, then select that database connection it shows (which I created yesterday) DW will re-upload the _mmServerScripts directory and scripts. I don't understand why this is happening.
I need a product that works. Do you have one? I have deadlines to meet and I have spent a nice amount of money for these problems.
Download the DataAssist BETA linked on the top of this web site. If you are using php7 you have to use a MySQLi connection and the BETA to generate the files since standard mysql connections have been removed as of php7 and only the beta supports MySQLi connections and code generation.
Lola
I will try it. But FYI the database connection I am using was created with MySQLi Server Behaviors Current version: 1.0.5 which I purchased a few days ago. It is a mysqli and I purchased it because of the fact that standard mysql connections have been removed as of php7.
The BETA should work with MySQLi. The release version of DataBridge does not.
Lola
*// That should be disclosed in the description of this extension as people add it to a shopping cart. I feel very misled!
I uninstalled databridge, then installed the one you linked me to. I removed all the previous pages and database and recreated the mysqli connection to the database. Go into dataassist with no database error. I configured a results page and click finish to generate the following errors:
error1.png is generated as soon as I click Finish
Did you close and re-open dreamweaver after installing?
Did the secondary installer run? You may have to switch pages to get it to initiate.
If you post your phone number I can give you a call and help you work through whatever is going on more quickly.
Lola
Yes I did close and reopen DW. The second installer did run and I entered the activation code. My number will be in the private section.
I called and after restarting Dreamweaver it all appears to be functioning properly.
Lola
After we disconnected I went to create a new results page. While in data assist pages I cannot add columns that I want to display. I click the + to add a column and nothing happens. So I tried to create a details page and again when I click the + to add columns to display nothing happens.
Lola
Closed DW and reopened and now its working. So strange. Very buggy.
