Error with WebAssist Search function
Thread began 7/17/2018 1:52 pm by sandy170299 | Last modified 7/18/2018 8:23 am by Ray Borduin | 835 views | 1 replies |
sandy170299
I have a form with 2 search fields on it, and I would like this form to filter a recordset on the page. This is my code:
<?php require_once('../Connections/etrends.php'); ?>
<?php require_once("../webassist/database_management/wada_search.php"); ?>
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: getPO;
//Searchpage: ;
//Form: ;
$WADbSearch1_DefaultWhere = "0=0";
if (isset($_POST["submit"]) || isset($_POST["submit_x"])) {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
//comparison list additions
$WADbSearch1->addComparison("PlaceID","".((isset($_POST["PlaceID"]))?$_POST["PlaceID"]:"") ."","AND","=",1);
$WADbSearch1->addComparison("OfficeID","".((isset($_POST["OfficeID"]))?$_POST["OfficeID"]:"") ."","AND","=",1);
//save the query in a session variable
if (1 == 1) {
$_SESSION["WADbSearch1_Psearch"]=$WADbSearch1->whereClause;
else {
//get the filter definition from a session variable
if (1 == 1) {
if (isset($_SESSION["WADbSearch1_Psearch"]) && $_SESSION["WADbSearch1_Psearch"] != "") {
$WADbSearch1->whereClause = $_SESSION["WADbSearch1_Psearch"];
else {
$WADbSearch1->whereClause = $WADbSearch1_DefaultWhere;
else {
$WADbSearch1->whereClause = str_replace("\\''", "''", $WADbSearch1->whereClause);
$WADbSearch1whereClause = '';
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
mysql_select_db($database_etrends, $etrends);
$query_getPlaces = "SELECT places.ID AS PlaceID, places.Name AS PlaceName FROM places";
$getPlaces = mysql_query($query_getPlaces, $etrends) or die(mysql_error());
$row_getPlaces = mysql_fetch_assoc($getPlaces);
$totalRows_getPlaces = mysql_num_rows($getPlaces);
$query_getOffices = "SELECT offices.ID AS OfficeID, offices.Office FROM offices ORDER BY Office ASC";
$getOffices = mysql_query($query_getOffices, $etrends) or die(mysql_error());
$row_getOffices = mysql_fetch_assoc($getOffices);
$totalRows_getOffices = mysql_num_rows($getOffices);
$query_getPO = "SELECT places.ID AS PlaceID, places.Name AS PlaceName, offices.ID AS OfficeID, offices.Office FROM places INNER JOIN offices ON places.ID = offices.PlaceID";
setQueryBuilderSource($query_getPO,$WADbSearch1,false);
$getPO = mysql_query($query_getPO, $etrends) or die(mysql_error());
$row_getPO = mysql_fetch_assoc($getPO);
$totalRows_getPO = mysql_num_rows($getPO);
<head>
<style type="text/css">
body,td,th {
font-family: Arial, Helvetica, sans-serif;
body {
margin-left: 250px;
</style>
</head>
<body>
<h2>Advanced Search by Places, Office, and Year</h2>
<form id="form1" name="form1" method="post" action="P-search.php">
<p>City:
<select name="PlaceID" id="PlaceID">
do {
<option value="<?php echo $row_getPlaces['PlaceID']?>"><?php echo $row_getPlaces['PlaceName']?></option>
} while ($row_getPlaces = mysql_fetch_assoc($getPlaces));
$rows = mysql_num_rows($getPlaces);
if($rows > 0) {
mysql_data_seek($getPlaces, 0);
</select>
</p>
<p>Office:
<select name="OfficeID" id="OfficeID">
do {
<option value="<?php echo $row_getOffices['OfficeID']?>"><?php echo $row_getOffices['Office']?></option>
} while ($row_getOffices = mysql_fetch_assoc($getOffices));
$rows = mysql_num_rows($getOffices);
if($rows > 0) {
mysql_data_seek($getOffices, 0);
</select>
</p>
<p>
<input type="submit" name="submit" id="submit" value="Search" />
</p>
<table cellpadding="2" cellspacing="0" border="0">
<tr>
<td align="center"><input type="hidden" name="WADbSearch1" value="Submit" /></td>
</tr>
</table>
</form>
</body>
</html>
When I preview the site in a browser, I get the following error: Unknown column 'OfficeID' in 'where clause'
I've included this field in my search criteria, and I can't see why it's not working. Also, when I try to edit the server behavior, nothing shows up. I will attach a screen print. I'm using Data Bridge 2.0.0. and I believe this is the Beta version, but I'm not sure how to tell.
Thank you.
We were able to get this working in a screen sharing session. I wasn't able to reproduce the issue with the server behavior not opening completely after our call, so let me know if you run into it again.
