product_update not showing data
Thread begun 7/13/2018 4:00 am by Jamie | Last modified 7/13/2018 2:52 pm by Ray Borduin | 1369 views | 2 replies |
Jamie
Hey Ray
Have got a backend set of product pages.
The results page is set to return a max of 25 rows before showing the pagination. If you go to, for example, page 2 and then click on one of the products none of the fields are populated with the products data. This does not happen on page 1 nor does it happen from a search page showing the results. the data is definitely in the db as if you search for a product on page 2 and access it from the search results it shows everything fine
Not really sure what is going wrong?
That is because the update page uses the same recordset name as the results page and the link passes a page number. The solution is to either rename the recordset on the update page with a find/replace or to remove the page number url parameter from the link.
Jamie
gotcha many thanks
